any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #371
picked up a 322-D model for a project, it had pieces missing, from the previous owner it ran good, he decided to change oil and fluids, then it would only start but no power for movement or blades, after several attempts the starter died and he gave up with it.
thus far put all parts back on, fixed the electrical to the solenoid and replaced the starter brushes, re connected the hydraulic lines he removed and as best the wires in the panel, thinking he tried to short wires to bypass the key switch
as of now it cranks, looks like fuel is getting there as white smoke sometimes comes from exhaust but not firing, fuel pump is pumping and getting to the block.
have not tried removing the fuel line to injectors to confirm fuel is getting to injectors but I see no fuel cutoff on the block, the throttle moves as it should but do not see a solenoid, there is a lever of sort with spring return but nothing attached, is there a cable for fuel shut off I am missing?
   / any toro groundsmaster fans on here? #372
You have to bleed all the air from the fuel lines or it won't start. Loosen the banjo bolt on the pump, turn the key on, the electric pump will send air and fuel out, tighten the bolt when no more air comes out with the fuel.
Loosen a fuel line at an injector, crank until you see fuel only, tighten the line and try to start. May have to keep cranking until two cylinders are working.
Here is the fuel shutoff on my 322D. Power is applied on the blue wires. You can also push in and hold on the rubber cap to stop fuel flow.
Is this a fuel pump that has been added?
The stock electric pump is on the left frame rail next to the fuel filter.
   / any toro groundsmaster fans on here? #373
On aT LEAST ONE OF MINE, THERE IS A LITTLE FILTER built into the pump housing. I think it was on the bottom
   / any toro groundsmaster fans on here? #374
Yep the parts list shows it:
   / any toro groundsmaster fans on here? #375
xfaxman, for some reason I figured the rubber cap was a manual fuel pump, I will try bleeding the lines and check the fuel shutoff blue wires for power
   / any toro groundsmaster fans on here? #376
Power may only be there to stop the fuel flow. My 325D kept running when the key was turned off, so I had to use manual shut off. I finally fixed it, but it was so long ago that I don't remember the fix. I think I pulled the connector apart to check voltage and found a pin not making contact. Pushed the pin back into the connector and it worked.
   / any toro groundsmaster fans on here? #377
well here is the update, bled the air out as above, found the break in the wire and now it runs like a top, the hydraulic had air also, it drives smooth and pretty fast on the ground considering it was not full throttle
deck is working as it should only issue is stopping
there are 3 pedals, I assume left and right brake?? the right one both brakes?? does this unit have diff lock?? now the issue all 3 pedals are sitting on the floor meaning they are full travel, maybe out of adjustment by previous owner but too dark tonight to figure it out
have a couple brackets and a micro switch left over, no idea where they go but I will take a few pictures of them and hopefully someone know what they are and where they go
   / any toro groundsmaster fans on here? #378
took another look at the 3 parts, a bracket, plate similar to Popsicle radial holes on the top and a micro switch, they show up in the hydro-static transmission diagram, micro switch is part 2, any idea what they do???
the cables on the two brake pedals are backed way off so thinking just snug them up so the pedal is off the floor
   / any toro groundsmaster fans on here? #379
View attachment 556483 View attachment 556484
you asked if its a fuel pump, its actually a filter, clear cylinder type
   / any toro groundsmaster fans on here? #380
2020 John Deere 7230R (A53317)
2020 John Deere...
2020 DRAGON ESP...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
2017 Ford E-450 Super Duty Shuttle Bus (A55852)
2017 Ford E-450...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
