Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,321
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,322
Ahhhhhhh okay, mine had set itself back to 11M. Reset to 300 and speed came back.
Now my router keeps resetting to wireless. Have reset the 3G/4G settings and the cable settings. Guess I should just be happy it's working.
Mines on 150M
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,323
Good to hear it is up and running again :thumbsup: my ar 150 was set to 72m and I reset to 150m but can't really tell any difference.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,324
Guys I'm having trouble with my setup....something has changed and I cannot connect the GLAR150 to the mobley.
I...thought...I connected via the usb between the two, but the documentation does not support that. I'm beginning to think two things. First I had this setup using WISP...I simply don't recall. Trying WISP now and cannot make it work. I know I ran into 'flakiness' with both the router and the mobley, almost sent the mobley in for repair, then it all just straightened out. Second, the GLAR160 is broadcasting it SSID...then it's gone, then back again, so to compound things, I think the router is acting up.
Bottom line how does everyone have these two hooked together? For several weeks, I've just logged on direct to the mobley, but the other things in the house that was networked, are suffering.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,325
My 300 was originally connected via cable I think. When the Mobley flaked out last week and i had to do the long press reset I ended up having to mess around with the router settings. Used the pics supplied by sodamo to get things going and it now says wisp. I can go into the 3G settings and click submit and it will switch to reading modem for a few seconds then revert back to wisp. I gave up trying to get it back to cable since it's working okay as it is.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,326
It must be WISP as the connection.
New problems.
The GLAR150 appears/disappears from network connections for unknown reasons. I have not caught the lights powering off on the unit itself...just the broadcast of the SSID.
The Mobley has taken to rebooting itself. Has done so several times this afternoon.
Not sure WHY both of these seemly unrelated problems are suddenly there. It's as if they both know I decided to come with grips what they are talking to each other, since it's so dang hot outside, ......and they decided to give the old fart some grief by throwing other problems into the mix.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,327
New problems.
I feel your pain. Dicked around with mine for two days last week. Holding the reset button for 30+ seconds as suggested by sd455dan got my mobley back to working. As I said my router also had to have some settings changed afterwards which I found weird since it never lost connection. I could connect with anything linked to the router even when I didn't have internet.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,328
For anyone interested...the GLAR150 is toast.
Replaced with a Trendnet AC750....problems gone. The interface on the Trendnet is much more to my liking than the GLAR150 too.
Time will tell....but everything back to stable for now.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,329
I tried the 150 at first but didn't know they came with internal OR external antennas. The one I received was the internal model. I sent it back and ordered the 300 with external antennas. Has an unbelievable 500 ft range.
My internet slowed to a crawl again yesterday and died when I attempted to reset. My problems have all been ATT or Mobley related I think. At least I have been able to communicate with my security cameras when the internet was not working.
The reset operation on my mobley is weird. One time it will display the red led and the next time it won't. When it seens to work and reconnect is when I hold it down for 30+ seconds and never see the red light.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,330
Recently my internet has been getting slower than tower congestion and sometimes stops working with a message about the DNS Server. I just turn off the power switch that it's AC power supply is plugged into, wait a few seconds and turn it on. Works fine for a day or two.
HYD TRANSFER TANK (A58376)
HYD TRANSFER TANK...
2012 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2012 GALYEAN 130...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
