Loader lift capacity on Grand L 5460/6060 HST cab
   / Loader lift capacity on Grand L 5460/6060 HST cab #41
The L47 is an industrial TBL rather than an ag machine. It's got a real frame I believe rather than just bolting the transmission housing to the engine to hold the machine together. It's designed to be abused with a hoe day in & day out. They tend to be 30% heavier per HP or something in that ballpark. The loaders aren't quick removable like on the Grands either.
I'd have looked at em harder, but I was upgrading to a cabbed machine & they have no cab options. They are also a fair bit more expensive than the Grands too.
I have a 2005 L39, first of the (L39/L45/L47 Line) somewhat Modified and reinforced here and there. I think I'd be on my 2nd or third grand L what I put that little bugger through. I've have quite a few posting on TBN about my L39, just do a search. A soft cab gets me thru the winter.
   / Loader lift capacity on Grand L 5460/6060 HST cab #42
Guys what's the process to up the pressure's? I think I need to up mine some also.
What is the recommended pressure for the 1055 FEL?
   / Loader lift capacity on Grand L 5460/6060 HST cab #43
The official answer is look at the specs on the owners manual and/or workshop manual. All Kubotas are within 50-100psi or so of 2,500psi though. Dont mess with anything until you confirm things with a pressure gauge.
The process to shim the tractor relief valve is in the workshop manual. It's the tractor hydraulics & relief valve, not the loader. Generally its adding some shim washers under the spring on the relief valve.
   / Loader lift capacity on Grand L 5460/6060 HST cab #44
Thanks Fallon... Mine is a HST tractor does that matter?
   / Loader lift capacity on Grand L 5460/6060 HST cab #45
Nope.
HST uses the common hydraulic fluid sump & fluid, but is otherwise completely separate. Its internal pressures are a lot higher than the other hydraulic systems. Its also much more revision surfaces & sensitive to fluid contamination. So it has it's own finer filter than the rest of the hydraulic system.
   / Loader lift capacity on Grand L 5460/6060 HST cab #46
Could someone with a workshop manual post the process to shim the tractor relief valve that is in the workshop manual by chance?
   / Loader lift capacity on Grand L 5460/6060 HST cab #48
Thanks for the Link Fallon... I looked threw it and didn't even see my tractor or FEL listed for some reason.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
FORD F350 SERVICE TRUCK (A52707)
FORD F350 SERVICE...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2018 ASV RT30 Posi-Track High Flow Compact Track Loader Skid Steer (A55851)
2018 ASV RT30...
