I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #1
jrsavoie
Clifton, Illinois
1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 Diesel Syncro transmission.
I used a John Deere filter and cleaned the screen behind the square plug.
When I started it after adding 10 gallons , it was squealing and the 3 point was jerky. I shut it off and added another gallon to top it off. It is still noisy and the 3 point is jerky.
I used Amsoil Tractor Hydraulic Transmission oil - I had it here - It's what I have always used in my 1975 Ford Backhoe.
Is there anything I did wrong? Is there anything more to changing the hydraulic fluid than dumping it, changing the filter, cleaning the screen and refilling?
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #2
Is there a bleed procedure? Do you have the service manual?
I never saw any bleed procedure in the manuals. The procedure was pretty much described as I did it.
I never read the manual cover to cover, and sometimes they do hide important info in odd places.
In the GM 6.5 diesel manuals they never say that 3 of the intake studs need sealant in the intake installation part of the book. I think the torque sequence is there, but if you don't know about the 3 studs, they will get installed without the sealant.
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #4
Is 11 gallons about what you caught from the tractor? I would have guessed it held 20 or so gallons of HYD fluid.
According to the book and the stick it's full. The book said 10 gallon for a change. I don't think they took the filter into account
I just noticed it says John Deere 400. That is supposed to be a John Deere 4010 diesel wide front Syncro transmsission
Is there somebody that can fix that?
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #6
With engine running a little above idle speed,foot off of clutch pedal cycle 3 pt up/down & operate steering to purge any air out of hyd system. 10 gallons is correct.
tHANK YOU MUCH
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #8
Changed title to 4010.
It is still jerking a little when raising the 3 point. The 3 point also drops rather quickly after the tractor is shut off
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #10
I had a 4000 that shook and jerked like that when first started, after it got warm it quit doing that. It dropped the lift arms too when shut off.
A 55+ year old tractor isn't going to be perfect.
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2019 Deere 310L EP (A53317)
2019 Deere 310L EP...
2015 BOBCAT T550 SKID STEER (A52707)
2015 BOBCAT T550...
UNUSED WOLVERINE PD-12-08D HYD POST DRIVER (A57193)
UNUSED WOLVERINE...
2023 Toyota Rav4 AWD SUV (A55853)
2023 Toyota Rav4...
