I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #1
jrsavoie
Clifton, Illinois
1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 Diesel Syncro transmission.
I used a John Deere filter and cleaned the screen behind the square plug.
When I started it after adding 10 gallons , it was squealing and the 3 point was jerky. I shut it off and added another gallon to top it off. It is still noisy and the 3 point is jerky.
I used Amsoil Tractor Hydraulic Transmission oil - I had it here - It's what I have always used in my 1975 Ford Backhoe.
Is there anything I did wrong? Is there anything more to changing the hydraulic fluid than dumping it, changing the filter, cleaning the screen and refilling?
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #2
Is there a bleed procedure? Do you have the service manual?
I never saw any bleed procedure in the manuals. The procedure was pretty much described as I did it.
I never read the manual cover to cover, and sometimes they do hide important info in odd places.
In the GM 6.5 diesel manuals they never say that 3 of the intake studs need sealant in the intake installation part of the book. I think the torque sequence is there, but if you don't know about the 3 studs, they will get installed without the sealant.
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #4
Is 11 gallons about what you caught from the tractor? I would have guessed it held 20 or so gallons of HYD fluid.
According to the book and the stick it's full. The book said 10 gallon for a change. I don't think they took the filter into account
I just noticed it says John Deere 400. That is supposed to be a John Deere 4010 diesel wide front Syncro transmsission
Is there somebody that can fix that?
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #6
With engine running a little above idle speed,foot off of clutch pedal cycle 3 pt up/down & operate steering to purge any air out of hyd system. 10 gallons is correct.
tHANK YOU MUCH
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #8
Changed title to 4010.
It is still jerking a little when raising the 3 point. The 3 point also drops rather quickly after the tractor is shut off
   / I JUST CHANGED THE TRANSMISSION / hYDRAULIC fluid in the 1963 John Deere 4010 #10
I had a 4000 that shook and jerked like that when first started, after it got warm it quit doing that. It dropped the lift arms too when shut off.
A 55+ year old tractor isn't going to be perfect.
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
S/N: 1240824 (A55853)
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
UNUSED PABREAK METAL BEAR SHOOTING TARGET (A57193)
UNUSED PABREAK...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
