Cat 1 pallet forks vs. carry all
   / Cat 1 pallet forks vs. carry all #21
Regarding the carry all mine is 15 years old built a 2 by 6 decking floor and 3/4 plywood walls. I think they are 4 by 3 1/2 feet. I load that up with all the firewood it will hold. Never had a problem
I think the brand is a Lienback
Mind the spelling
Ray
   / Cat 1 pallet forks vs. carry all #22
The Carry All I had on my older tractor worked well with a home built deck and back panel much like the picture in post #18.
Now with the tractor we have (bigger) I'm going to get a set of 3pt pallet forks, build a similar deck and back board, but bigger as this tractor has more capacity.
I use pallets with walls on 3 sides or cages from liquid totes to stack and move firewood.
My 5 cents of opinion.
   / Cat 1 pallet forks vs. carry all #23
I've got the 3-Point Pallet Fork, 2,000 lb. Capacity sold by Agrisupply.
Works well on both my tractors, easily slides into/under pallets.
Great info and pics. Thanks to all.
Before I pulled the trigger on either the TSC carry all or a fork attachment, I decided to see what I could do with what I had on hand. Part of this inspiration is because we're in the middle of a house building project, and there's a ton of scrap available to me at the moment. I came up with this carry all deck for my box blade, using nothing more than pallet wood, scrap 2x4 and 2x6 lumber, nails taken from pneumatic strips that house framers seem to discard like cigarette butts (I've probably got 30lbs. of nails picked up from the yard), and half a box of screws. Total cost, after I paint it, should be about $10.
Base is made of 2x4s, fitted to the recesses in the box blade:
The decking and edge banding are from pallet wood. The fiber cement siding for our new house is delivered on long pallets, about 16 feet long. Lots of long, straight pieces of SYP in those pallets, sturday and very useful once the nails are out. The uprights, which will support a tote box made from pallet wood, are 2x6s.
Here's the tote box. It's already loaded up with the tools I used to make the carry all.
And the final product, ready for some limbing work around the homestead.
The carry all is only connected to the box blade by gravity. I ran a few tests to check stability, and found one problem I will have to address: Going downhill, if the tote box is filled with gear, and there is nothing on the deck, the carry all wants to tip forward onto the quick hitch. I'll have to add some type of attachment to prevent that. I also tested it by transporting about 300 lbs. of cut logs. Worked great. Was able to get a satisfying amount of log sections on the platform. They were stable. My steering was a little light with that much weight on the back (5' box blade, platform, logs, tools), so I may add a couple more suitcase weights to my front fender.
Still have some more mods to do: Holes, hooks, tubes, etc., to make it more versatile for carrying long handled tools, rope and chain, among other things, and of course, painting. I made the carry all platform 4" wider than the box blade on either side. Might add legs to it so it can stand alone, but for now, the extra width allow me to set the carry all down on some stacked cinder blocks. It's not hard to take it off by hand when it's empty. Just a bit awkward.
With this setup, I can't achieve one of my goals: Rolling a log onto the platform using a timberjack, as I might with a lower carry all or forks. Thinking about other ways to solve that issue. But overall, I'm really happy with it. Although I was only able to use it for actual work for about 3 hours today, it was incredibly handy.
   / Cat 1 pallet forks vs. carry all #27
I picked up one of these from Titan and now I can just put my regular quick-attach pallet forks or even a bucket on the back of the tractor. I also have a hydraulic top link which you kinda need to be able to hook things onto this adapter. Note, it didn't fit my cat-1 quick hitch so I modified mine to work.
If you go to the palletforks.com website you can find this quickly by seaching the item number which is 3PTQTA.
   / Cat 1 pallet forks vs. carry all #28
   / Cat 1 pallet forks vs. carry all #29
I've shown this pictures on here before but this is what I use when I am deep in my woods. Fill the bucket and carry all with the wood I split. Figure I can carry more after it's split rather than before. IMG_20180616_120523.jpgIMG_20170924_135648 (1).jpgIMG_20170924_135658 (1).jpg
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
CATERPILLAR 279C SKID STEER (A52709)
CATERPILLAR 279C...
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
