Why are TYM and Branson so much less??
/ Why are TYM and Branson so much less?? #1
tjklein
Member
NJ
none
Guys looking for a tractor for my dad= It seems that the TYM and Branson are thousands less than - Kubota,MF etc- Since we do not have any dealers close by have to this long distance- Are the Kubotas,MF etc that much better or am I paying for the name and advertising $$$-
Also after doing some reading here it seems for mowing 15+ acres Hydro is rec. but is it that much better than syncro which is what he is used to-
Thks for all the advice
/ Why are TYM and Branson so much less?? #2
We need to know your location /city/state/region.
/ Why are TYM and Branson so much less?? #4
Kubota is a Japanese tractor , Branson and TYM are made in south Korea. I would say that all compact tractors under 60 hp are made overseas i.e. South Korea, Japan and India.
/ Why are TYM and Branson so much less?? #5
Kubota was once an up and comer. Now it is an established brand. Montana Tractor was once an up and comer. Now it is an orphan tractor (out of business). The question is what will TYM and/or Branson be in the future?
/ Why are TYM and Branson so much less?? #6
Good point but just to be fair it must be noted that Montana never made tractors it was just a brand name. Montana tractors sourced their tractors from LG's tractor division. LG spun the tractors off with LS Cable in 2005 and the tractor division was then called LS Tractors. In 2009, LS Tractors decided to enter the US market directly and stopped making tractors for Montana. Montana attempted a merger with Kukje's Branson division but it fell through and by 2010 Montana was gone.
/ Why are TYM and Branson so much less?? #7
Montana never built their own tractor, just branded. (as mentioned above they sourced from LG)
TYM and Branson make their own.
/ Why are TYM and Branson so much less?? #8
Korean products are usually cheaper than Japanese products. Simply put, the Koreans work ethic and work culture is insane and they have huge cost productivity. My company distributes a Korean ductless company's products and I was told by US executives that in Korean culture if the boss wanted to take you to dinner and then go drinking all night you simply complied and went with the boss and then went back to work again in the morning with no sleep. Their culture expects you to work work work. However, the current government is trying to change this policy of overwork and they created a new law originally effective on July 1st (they are now giving 6 months for larger companies to implement the law) restricting companies from being able to force workers to work so much during the week. Now they are only allowed to schedule workers for 52 hours a week.
/ Why are TYM and Branson so much less?? #9
Why do Korean cars cost less than Japanese cars?
/ Why are TYM and Branson so much less?? #10
By being cheaper than the others, doesn't actually mean that the tractor is built cheap. For instance, with Branson (the brand I have experience with), the tractor has a lot of quality. It's built heavier and stronger than probably any other brand. The castings are huge, the tractor is welt built and you actually get a real hood and fenders made of metal instead of cheap flimsy plastic. You can see quality that you can't see in some other brands.
People are a bit skeptical about this brand, probably due to misinformation and mostly by the under-advertising it gets by the brand. But if you can actually sit in a Branson tractor, you will see what I mean, specially if you have any other brand on the side to compare. And I'm sure the Branson users can relate to this.
The John Deere power reverser series, I believe the 6M and 6R series, are built by Branson. Same for the McCormick X1 series, which are actually a clone from the Branson 20/25 series.
/ Why are TYM and Branson so much less?? #11
I don't know anything about Branson, but the TYM I looked at was a very nice machine. I saw a few things that could be better but overall it was a very nice machine.
/ Why are TYM and Branson so much less?? #12
I have a 2004 century 2535 (Branson 3510) and a 2015 Kubota MX 5200. Both are very good tractors, but the Century which is only 35 hp weighs almost as much as the Kubota. It is well made with heavy castings as others have noted. Each tractor has its various strengths and weaknesses. Biggest challenge for the Century is having a dealer located nearby. The nearest one is almost 50 miles from me yet within that radius there are at least 3 large Kubota dealerships. As for the cost, MGRRMD is accurate about the work ethic. When combined with a smaller advertising and promotional infrastructure and a less extensive dealer network you have opportunities for cost savings. Check out the Century/Branson forum for more information and perspectives. W. Jones
/ Why are TYM and Branson so much less?? #13
I bought a Branson because I liked their amenities. There wasn't a Kubota dealer close enough to me to consider them.
Speculation: Large companies have large overheads and popular ones have brand recognition....both add to the cost.
The only thing i initially disliked about Branson was their customer service was setup for dealer-customer interface. Before I knew where to ask the question to get the desired answer...complicated question, I attempted to get it from the Rome, Ga. facility and was not satisfied with the service.
On quality of the product, go and look at one and kick the tires. Plenty of quality there and now that TYM has bought Branson (as I have learned from others) the company is much larger and any concerns about having replacement parts in the future should be eliminated. I speculate that TYM bought Branson to eliminate a competitor and to get access to the Cummins engine license that Branson possesses.
/ Why are TYM and Branson so much less?? #14
I’ve been fairly impressed with the new RK tractors, built by Korean TYM with Japanese Yanmar engines. I see no reason why they’d be any less quality than a John Deere that’s made in Mexico (or wherever) and also uses a Yanmar engine.
/ Why are TYM and Branson so much less?? #15
When I got my Branson I had checked out most all the other brands also as far as features and abilities.
The Branson's seemed heavier and beefier in the frames and rear end housing then any of their competitors,
as well as being less money and in most cases less money and more or better features.
As far as the TYM / Branson acquisition/merger the Branson at this time are still a heavier tractor in the same range.
While being heavier may not equate to better, to me a beefier housing is better then a light weight one.
/ Why are TYM and Branson so much less?? #16
TYM (Korea) makes Mahindra, RK, Branson, and also TYM-branded tractors. The price differences you're seeing may simply be the different pricing strategies you'd expect between more established companies like Deere and Kubota vs "up and comers." There may or may not be important differences between the actual tractors.
Well-known companies with longstanding reputations (deserved or not) such as John Deere and, increasingly, Kubota can market themselves as "we're the best" and therefore can charge more. To complete with this, less-well-known brands ("up and comers") may adopt a "better value for your money" strategy, thus the lower prices.
/ Why are TYM and Branson so much less?? #17
It's pretty common in many markets for up and coming companies hoping to grow market share, to make less profit while establishing a brand. And, as was already pointed out, there may be less spent on marketing. From what I can see, Branson barely spends any money on U.S. marketing. Their web site is rarely up to date. I suspect their budget for trade shows, sales brochures, dealer support, etc., is dramatically lower than Deere, Kubota, etc. They pass that savings along to buyers, as part of a pricing advantage. If they win more market share and shore up their position in the market, they may change that over time. That would be normal.
There is more risk with a lower market share brand, that they will give up on the market, or the market rejects them. That was less of a concern when tractors were simpler. It's a greater concern now that it's harder to do shade tree work on a newer tractor.
/ Why are TYM and Branson so much less?? #18
Tym does not make Branson tractors. Branson makes it's own tractors.. Tym and Branson just completed an acquisition as a group so they are still two separate companies.
/ Why are TYM and Branson so much less?? #19
Bought a 2009 Branson 3820i in late 2009 after looking at and testing all other major brands, Kubota, MF, Kioti, Deere, NH, Mahindra, available in my area. I got the Branson because of the build and the "Cummins" engine. I have not been disappointed. Use it for grading 1/2 mile gravel drive, moving stone and dirt, hauling logs out the woods, flail mowing and bushhogging, snow removal and about anything else you can think of. No problems or failures other than a broken clutch pedal spring and a tail light that was knocked out in the woods by a limb. The heft of this tractor, along with the quality of the build really make a difference! While all the brands I considered were quality machines, I made the right choice for me. Dealer is about 30 miles away and has great service so that has been another plus.
/ Why are TYM and Branson so much less?? #20
If not in a big hurry, keep doing your due diligence to come to a conclusion.
As far as your second question, I like shuttle for mowing and your dad would be fine with that transmission, preferably a 12/12 over an 8/8 with power reverser (power shuttle). Are you getting a FEL too for other tasks? Then hydro may come into consideration. For mowing 15 acres with hydro make sure it he tractor has cruise control.
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A60430)
2007 FORD F750 XLT...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2017 CATERPILLAR D6T LGP CRAWLER DOZER (A60429)
2017 CATERPILLAR...
