30x50x16 pole barn construction
   / 30x50x16 pole barn construction #62
Day 5. That platform truck is super. Should finish up the front tomorrow. View attachment 565765
Look at that. Our crews hired the same truck!
   / 30x50x16 pole barn construction #64
Pole barn is named for the construction method of using poles, it can be open or sided. It's proper name is post frame construction. Also see NFBA, National Frame Building Association.
   / 30x50x16 pole barn construction #65
Fairly common now days. They are the same shape as the roof metal. Does make a big difference.
Just wondering if you considered putting them across the side at the top, just under the eave? Do you get much hail in your area?
Very NICE Building!
   / 30x50x16 pole barn construction #66
Skylights in the roof?
A good friend was painting his barn roof and his new bride came up to help. She stepped on a skylight, fell thru and died.
He later killed himself, never got over it. Sad..
   / 30x50x16 pole barn construction #67
All this debate about truss design ... I think everyone needs to take a look at the pictures again.
It appears to me the only 2x4's in the trusses are the web. The bottom cord looks like 2x6 and the top cord looks like 2x8.
   / 30x50x16 pole barn construction #68
Nobody is talking about the trusses. They look perfect. The purlins are the boards that span the distance between the trusses. To some of us who build and work on houses for a living, they are smaller for such a long span, then we would use. While they are probably fine, it is just a little surprising to see them up there.
   / 30x50x16 pole barn construction #69
Ahhhh, my mistake. I apologize.
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2001 John Deere M665 (A50120)
2001 John Deere...
PALLET OF GOLF CART TIRES (A51248)
PALLET OF GOLF...
DOOSAN DL300-3 HYD 4N1 COMBO BUCKET (A51247)
DOOSAN DL300-3 HYD...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
