Wood Chipper recommendations
   / Wood Chipper recommendations
GEM - - WHOA!!!!! The owners manual with your new chipper should have EXACT instructions on how to shorten your PTO shaft - if its necessary. If you do not have exact instructions - - let me know - - I will attach exact instructions to a post here. Don't play silly games with the PTO shaft shortening. At the very least - it can cause serious damage to the chipper or your tractor.
I sure did find the instructions, read them, and understood them. As well as a dozen other video's on youtube. All are a bit different methods in the measuring, but the results were the same. And I did for sure get the measurements correct for the cutting. It was the protective outer tube guard that ate my lunch.
The first of 4 times I took it off and put it back together, the large end caps just snapped right in place; no problem. Then that last time - it just would not go back together, no matter what I tried. Upon close inspection, I 'think' I broke the nylon bearing collar on both ends. At least they do pull apart very easily and won't snap in place.
I went ahead at put the sleeves on loose and chained them to the tractor for a measure of safety. I've also found that Tractor Supply sells replacement parts for that PTO as well. Mine seems to work fine, but I'd like it to be 100% correct and safe, so I'll take mine to TSC and see if I can buy the replacement parts.
PS - That Woodland WC68 is one hoss! I'm loving it!!!
   / Wood Chipper recommendations #32
Ha - - GOOD on you. I think I used my first chipper - Wallenstein BX42S - at least a dozen times before I realized there were grease zerks on the plastic PTO shaft cover. Soooo... something broke on that cover - - I just chained it on to one of the lower arms and went on about business. On my new BX62S I grease the cover/shield zerks right along with everything else.
   / Wood Chipper recommendations #33
I have a Wallenstein PTO chipper rated for 4". It self feeds, too. I paid $1,900.00 for it. I'm likely going to sell it as I haven't used it for several years.
I found 4" to be plenty big enough. Anything bigger than that I keep to burn.
   / Wood Chipper recommendations #34
Delivery from Buffalo, NY to Warm Springs was 7 days after placing my order. Heck - that's Amazon kind of service!
Small world, I'm over in LaGrange. :) I too went with the Woodland Mills WC68 and mine is supposed to be delivered tomorrow.
   / Wood Chipper recommendations #35
Anyone know the flywheel weight of the Woodland Mills WC88?
   / Wood Chipper recommendations #36
Excellent question - their web site specs list EVERYTHING except the weight of the flywheel.
However - I can give you an approximate weight - - my Wally BX62S flywheel - 30" x 1" = 197 pounds The Woodland Mills WC88 flywheel - 24" x 1" ~~ 160 pounds.
You're going to like the WC68. Let me know if you want some training and/or experience in the cutting & stacking phase :) Seriously, if you need any help with the assembly, let me know and I'll come give you a hand.
   / Wood Chipper recommendations #38
I found the WC68 spec-ed at 120#, can't remember the reference sorry. Even at 160, four blades seems like it's going to ask a lot more of the PTO than the Woodmaxx with two blades and more flywheel.
I'm still in decide mode so no flaming please;)
   / Wood Chipper recommendations #39
How about a demo 20 miles east of columbus:D
   / Wood Chipper recommendations #40
I've only had one problem with the Wally chippers and it had NOTHING to do with flywheel weight. When I had the BX42S on the 26hp Ford 1710, the discharge chute would plug up because pine pitch would coat the inside of the chute. Solution - cut, stack and then let small pines dry for a year prior to chipping.
My new Wally BX62S does not have the pine pitch plugging problem - larger discharge chute - higher air flow.
One thing I have noticed, for sure. Heavier flywheel means smoother chipping. The difference between the BX42S vs BX62S is noticeable.
JMHO - but about the only advantage of going to any chipper that can handle anything bigger than 6" diameter stuff - heavier chipper flywheel.
Its a real PITA for me to drag and stack 6" diameter pine trees. I can do it for about two hours and then its break time.
If I had a chipper that could handle trees bigger than 6" butt diameter - honestly - it would not do ME much good - I could not drag the cut trees out to stack and chip.
If you need a real monster chipper - - Valby - - they have PTO driven models that have 600+ pound flywheels - will chip up to 10" material.
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
Wright Sentar (A50120)
1997 John Deere 8100 MFWD Tractor (A53472)
1997 John Deere...
2018 JOHN DEERE 5075GN LOT NUMBER 100 (A53084)
2018 JOHN DEERE...
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
