Anyone drilled a hole in the end of a pallet fork
   / Anyone drilled a hole in the end of a pallet fork #12
To accept a trailer ball for moving trailers around? Sounds like a reasonable idea unless I'm missing something.
A lot of better ideas: trailer ball for forks - Google Search
No wrench needed:
   / Anyone drilled a hole in the end of a pallet fork #13
I put a 1 & 1/4 inch hole in the fork of a 4000 lb. rated forklift with an annular cutter in a mag drill. It went through like a 3/4 spade bit through a 2x4.
   / Anyone drilled a hole in the end of a pallet fork #14
No wrench needed:
I made almost the same style, fits over both fork and has tube for stinger. Slide it on for the strength of both forks, chain to back plate and uses lever style load binder. On or off in a minute and very secure. The hardest chore for the setup is moving the forks into position.
Moving heavy loads using one fork IMO would tweak the fork.
   / Anyone drilled a hole in the end of a pallet fork #15
Dont know about the whole legal vs not-legal thing. But will say that the towlift tech that works on our lifts at work....I specifically asked him about this.
His exact words were....drilled hole is okay. Torched or plasma cut holes....he is required to take lift out of service.
I have drilled many forklift forks. They are not as hard as people think. Really not much different than just drilling steel of similar thickness.
Figure out the size drill bit you want to use....pilot hole just slightly larger than the web of the drill (if chisel point)....then right to size. No problem at all.
   / Anyone drilled a hole in the end of a pallet fork #16
I can image a fork failure on one side under an extreme tip load would be dangerous. Propagating cracks would come more from irregular holes.
   / Anyone drilled a hole in the end of a pallet fork #17
And there is a big difference in drilling a hole for a ball to move a trailer....or for a pin to prevent something from sliding off
vs
hanging a shackle or clevis on there and lifting for all she's got
   / Anyone drilled a hole in the end of a pallet fork #18
Oh, she's got more than that! And I am always mindful of fatique and possible failure at any time. As it sits, I have been doing that for about fifteen years with no sign of trouble.
I built the sleeve for the fork end with a 2" receiver. It's kind of sloppy despite adjustment bolts. A two fork thingie would be MUCH better. Depending on what you are pushing or pulling around, the single fork thingie is hard on the fork carrier.
THIS is a bit much for a single fork receiver.
   / Anyone drilled a hole in the end of a pallet fork #19
If the OSHA people ever saw some of the crazy stuff people do with forklifts they would probably outlaw them completely. :confused2:
   / Anyone drilled a hole in the end of a pallet fork #20
We’ve picked up forklifts with bigger forklifts usually because we got the little one stuck in the parking lot. We overload them and tip them forward pretty often ( all overloads are low to the ground where tipping forward is pretty much the only bad outcome) and using a pallet to change a shop light bulb is the “best” way.
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2022 Horizon Trailer (A55973)
2022 Horizon...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
