Kubota BX2680 5-Hr Service SHOCKER
   / Kubota BX2680 5-Hr Service SHOCKER #1
Williamsburg, VA
Multiple JD, Kubota
Ok folks, this you won't believe. Had my son, who is a Master Diesel Tech @ a local Ford dealer do the FIRST 50-hr service on one of my smaller tractors. Pictures of the trans/hydraulic strainer tell the horrible story and this is the CRAP the Kubota Factory is leaving in their machines. My guess it's Permatex, RTV or some gasket disintegrating.......................Kubota should be ashamed of themselves for this nonsense.
   / Kubota BX2680 5-Hr Service SHOCKER #2
That is normal for a new machine. Hence why you do the mandatory 50 hr service.
My BX2200 that was built in 2002 occasionally will have stuff in the strainer. That's what it is supposed to do.
Between that strainer and the micron filter, it cleans up the fluid well before it goes to be pressurized.
Got around 1600 hours on my machine and no issues.
Folks -- I have owned over 50 tractors of all colors and arguments that this is "normal" have low credibility.
Plus, my son, an ASE, Ford Certified Master Diesel Technician who did the service and who has worked on thousands of diesel engines, transmissions, including 10 years at CAT working on million dollar systems, etc. says "this garbage" in the hydraulic system is laughable, clearly a factory screw up.
   / Kubota BX2680 5-Hr Service SHOCKER #5
Hmmm I seem to recall working for a tier 2 f*rd supplier making tranny parts for some high volume car with internal passages that could never get cleaned properly because of the part's design...maybe we should have called ASE, Ford Certified Master Diesel Technician to save the day...
   / Kubota BX2680 5-Hr Service SHOCKER #6
What does this comment have to do with the issue? :confused:
   / Kubota BX2680 5-Hr Service SHOCKER #7
Ok, there痴 a bunch of crap in the screen. Did the hydraulics exhibit any abnormal symptoms? Cavitation, low flow? Nobody is going to refund your money, trade you a new tractor or reimburse you in any way. Get over it and move on.
   / Kubota BX2680 5-Hr Service SHOCKER #8
The pics show a little more crud than I had when I did my 50hr. But I think you are way over-reacting to a fairly normal thing.
   / Kubota BX2680 5-Hr Service SHOCKER #9
View attachment 568237View attachment 568238
This is why the first service is so very important.
It is also why one should change both filter and oil at first service, regardless of what the owner's manual says.
SDT
   / Kubota BX2680 5-Hr Service SHOCKER #10
Well I am one that believes that there shouldn't be any 'crap' left behind by manufacture/assembly. It shows poor quality control. Maybe in this day and age its normal but it shouldn't be. Maybe a little negative feedback instead of a shoulder shrug would help Kubota do a better job.
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
