UGGG.....the quest still continues.
Seems for each question I get answered, two more questions arise out of the answer. And havent had much luck getting explanation...
Got a line on a new engine locally for $6250 cash OTD. But thought I'd make some more calls...
Called a place this morning to see if they had any engines....explained the situation about my balance shaft tearing up the block rendering it useless as a core. He questioned the balance shafts and why it had them. And said every V2403 engine he has done doesnt even have the shafts.
He said some of the JD engines have balance shafts, but they just balance the rotating assembly, plug the oil holes, and toss the balance shafts in the trash. And free up HP doing so. But didnt know if that was possible as he only ever worked on non-balance shaft V2403 engines.
So it seems that ONLY the V2403's that went in tractors got the balance shafts. Non of the skidloader or industrial (compressors, generators, etc) stuff got them.
So I called the place back here locally that is the kubota "authorized engine service center" and they didnt really give me much info. confirmed that yes only the ags got the balance shaft, and without them it would rattle your teeth out.
I asked him about industrial engines, just an off the shelf crate engine dropping in. All I need is a power source to marry to the transmission right? Sure I'd have to change the bell housing adapter, use my clutch which will probably mean my flywheel too. But he couldnt comfirm if the balance shafts were specific for the engine, or if because the tractor as a whole required them:confused3:
So on one hand I am thinking....I just need to drop an engine in and make the flywheel go round right? pretty simple even if having to change a few external components, like brackets, bell housing adapter, maybe even the oil pan as I dont know if the industrial ones are cleared for the driveshaft. But no big deal.
But on the other hand....why in the world would kubota design a different engine....with balance shafts....only for ag tractors. Why wouldnt they use the engine already designed to go in skidloaders, industrial stuff, etc.
I dont want to spend $6k for an engine that will tear itself apart in a tractor application. But I also dont want to spend $1200 MORE to get one from a dealer (which comes with fewer parts like starter and alternator) if it isnt necessary.
