Jchonline
Elite Member
- Joined
- Feb 19, 2018
- Messages
- 3,089
- Location
- Red Feather Lakes, CO
- Tractor
- Kubota L6060, KX040-4, M7060, X1100C, M62(S)
The M62 is 47 HP to the PTO. In the hud-son specs are they talking engine HP or PTO HP?The winches have a slip clutch which is adjustable. If properly adjusted, it's unlikely your tractor will damage the 35M due to overpowering the PTO. However, you are right smack in the middle of the suggested range for the 45M. You didn't mention you're tractor model (I'm assuming your aren't talking about the M62 that is "to be delivered" in your profile, since it's not 47HP), but if the 3PH lift specs match those of a typical 47 PTO HP tractor, the 45M (or a Farmi 501 or similar) would be a good match for your tractor.
As mentioned earlier, I own the 35E, previous model to the 35M. It's a solid winch, and gets the job done for me. However, if I had the tractor like yours, I'd be getting the winch to match it. My winch is a good match for my tractor. Had I bought smaller, every time I get a log that I just can't quite move, I'd be kicking myself for not buying an implement that matched my tractor.
That asked, still great advice. I can splurge for the 45M. Thanks!
