   / Your last generator Maintenance Run #1,901
I started this thread, thinking if a few guys stop by, that'll help me remember to git'er done myself.....
Along the way, I've learned a lot about generators - big and small, wiring issues, interesting add-ons, and seen some really nicely done installations and fab work.
I'd say that I like hanging out in this thread more than watching TV.... but that's damning with faint praise :drink:
Rgds, D.
Yeah thanks Dave! I think I first posted in your thread about 4 years ago and it has been a great reminder for me to frequently get out to fire her up and check on the battery and tender. Not to mention learning more about generators and people's set ups more than I ever dreamed. :confused2: :drink:
For us, no worries. If it gets high enough to threaten the house, there had better be an Ark out there somewhere. Some nearby roads can get over-flow from nearby farm ponds if things get bad. In town (6 miles away), some streets get inundated if the storm drains can't keep up. That's about it.
Sounds like a "normal" heavy storm here.
Good to hear that you guys are not seeing the 100+ year events some people have seen this season.
Rgds, D.
What I've always liked about engineering.... peel back a layer, and there's usually n layers underneath to learn....
Rgds, D.
   / Your last generator Maintenance Run #1,904
Rgds, D.
Ain't that the truth. One graduates with an engineering degree and other than the theory, you don't know nothing. Experience is the real learning. I do hark back to my schooling and wish I could go back... just no tests and grades.
   / Your last generator Maintenance Run #1,905
My monthly maintenance regimen is paying off now. Generator has been running non-stop since 3PM yesterday and will probably continue for several days if not weeks.
   / Your last generator Maintenance Run #1,906
I'm with you JD855guy.
I got ready for Florence last month. Moved the generator up from my workshop, purchased 30 gallons of gas, charged up the battery, etc. Like the idiot I am I used up the 30 gallons of gas I had stored for the generator. Yesterday I went back and purchased another 16 gallons just in case. As luck would have it our power went out at 11:23 am yesterday. Glad I got the extra gas.
One thing I noticed is that the clocked hours on the meter is 1/2 the actual run time. Don't know what's up with that unless it has something to do with load on the unit.
   / Your last generator Maintenance Run #1,907
I'm on hour 43 of straight running. My unit is diesel and has only used 21 gallons in that time.
I had used a lot of my reserve fuel in the tractors. Fuel truck is on the way.
   / Your last generator Maintenance Run #1,908
JD GUY what size is your generator and what is the average load?
90cummins
   / Your last generator Maintenance Run #1,909
I have a 15 HP gas generator rated at 8KW continuous and 10KW surge. The literature says it will run 11 hours on 8 gallons of fuel at 1/2 load. I guess they figure 1/2 load is a good guesstimate. I typically get between 12-14 hours so I must not be loading it too hard. With the 8 gallon tank that is a a pretty decent run time for an emergency generator IMHO. I would guess your unit is much larger than mine.
   / Your last generator Maintenance Run #1,910
90cummins
My generator is a military surplus MEP-803A. Rated for 10KW continuous @.8 power factor. Loads vary. I'm showing a little over 15 amp draw on it right now. Yesterday while we were drying clothes and cooking it had 52 amps on L1 and 54 on L2.
I built a resistive load bank that will load it to 13.5K and it runs it without a problem.
   / Your last generator Maintenance Run #1,911
Congrats on having the right tool at the right time. Wish we could have an outage.:cool2:
   / Your last generator Maintenance Run #1,912
Nice unit, and that is an impressive fuel consumption, 43 hours and only 21 gallons.
And I thought diesels were evil ?
Yeah..... about 1/2 gal/hour - with what JD has been running, can't beat that !
Rgds, D.
   / Your last generator Maintenance Run #1,914
Rgds, D.
Not in my mind :drink:
I have a 25 KW PTO unit, depending on what tractor I put on I will average a bit more then 3/4s of a gallon per hour.
It doesn't matter much what I have for a load on it fuel consumption stays about the same.
Fitting that it's a Mil unit.... the old saying "The more you train in peace, the less you bleed in war" comes to mind.
For the extended run you have coming up, an under-stressed 1800rpm machine like you have is the cat's PJs, for sure.
Here's hoping that everyone in your area is doing OK, and continues that way....
If you have the #'s handy at the end, please post total hours and total fuel, that would be interesting to see.
Rgds, D.
:drink:
Yeah, unfortunately that characteristic of diesels seems to conveniently get left out of the public "green" conversation.
Rgds, D.
That is odd.... a lot of the basic hour meters sense vibration. If you had a 3600rpm meter on an 1800rpm unit, that would make sense, but I don't think that's the case for you....
Replacement 3600rpm hour meters should not be expensive, but if it's tracking 1/2 time consistently, I could probably live with that...... I'd add a label, but that's mostly just me sleeping better at night..... :)
Rgds, D.
   / Your last generator Maintenance Run #1,918
Got hold of a Yamaha EF2400iSHC a while back . Changed oil , took covers off too peak inside looks too be well made . My first Yamaha ever . Probably add an hour meter to it . I didnt pay that for mine but these things run a little pricey new at like $1330 and then some starting price . From what I have read you cant "parellel"this model like some Honda"s etc .
No biggie to me never had any intentions too I have larger capacity gennys if more watts needed etc . Some reviews of these units say it has no fuel level indicater mine does along with fuel screen . Use mine to run power corded tools out in field . One pull starts . Also like fuel shut off feature while its running to keep fuel out of carb while sittin . Just a sharein my thoughts on this model .
Nice !
IIRC, someone on TBN (maybe even a ways back in this thread) was using one of those quite a bit on his highway tractor..... all the comforts of home, quietly, on not much fuel :thumbsup:
Yamaha is well known for engine tech, you should have great service out of that unit.
Rgds, D.
   / Your last generator Maintenance Run #1,920
There is a tread on here somewhere about gray market generator motors and I can't seem to find it any help ??? What I have is a Yanmar clone 189f motor in my generator that won't stay running. All new filter and fuel lines, I bleed it and all is fine at first then after about 3 sec. it starts stumbling and rpm drops,, like it's running out of fuel??? Any help would be appreciated …
2025 CATERPILLAR 255 SKID STEER (A60429)
2025 CATERPILLAR...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2013 Ford F-150 Pickup Truck (A59230)
2013 Ford F-150...
Takeuchi TL150 Compact Track Loader Skid Steer (A59228)
Takeuchi TL150...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2013 Ford F-550 Passenger Bus (A59230)
2013 Ford F-550...
