Bending 6" square tubing with 1 side removed
   / Bending 6" square tubing with 1 side removed #11
Or cut completely through for 2-3 inches, then leave 1/2 inch, then another slot, etc. Spred. Weld when finished.
Bruce
   / Bending 6" square tubing with 1 side removed #12
If you cut it into pieces, rather than part way through, you need to accurately hold it in place, and tack it back up, = more work.
Skipping areas when you are cutting it, also = more work. And, it will not bend as cleanly, in the areas where it's full thickness.
Thanks for all the tips guys! As luck would have it, a friend who works at a machine shop said it would be easier to bend a new piece on his brake then to bend my metal. He should have it ready tomorrow. Thanks for all the help... I got lucky!
   / Bending 6" square tubing with 1 side removed #14
Scissors jack could fit in there probably. Might bend it funny though. I liked the suggestion of cutting it and welding inthe desired position
   / Bending 6" square tubing with 1 side removed #15
We need an update, please.
   / Bending 6" square tubing with 1 side removed #16
It would be very difficult to press a pipe into the corner to spread the sides of 3/16" x 14 inches long. Maybe a 1 1/2" solid bar but not a pipe.
Bruce
With a 1/16" abrasive cutoff blades on an angle grinder you could cut a slot 1/8" deep the full length of the 14" corner, bend it open, then weld up the slot and grind the corner round again.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2019 FREIGHTLINER...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2025 Star EV Capella Electric Cart (A55853)
2025 Star EV...
200356 (A51406)
200356 (A51406)
CATERPILLAR IT38G SERIES II LOADER (A52706)
CATERPILLAR IT38G...
