Bending 6" square tubing with 1 side removed
   / Bending 6" square tubing with 1 side removed #11
Or cut completely through for 2-3 inches, then leave 1/2 inch, then another slot, etc. Spred. Weld when finished.
Bruce
   / Bending 6" square tubing with 1 side removed #12
If you cut it into pieces, rather than part way through, you need to accurately hold it in place, and tack it back up, = more work.
Skipping areas when you are cutting it, also = more work. And, it will not bend as cleanly, in the areas where it's full thickness.
Thanks for all the tips guys! As luck would have it, a friend who works at a machine shop said it would be easier to bend a new piece on his brake then to bend my metal. He should have it ready tomorrow. Thanks for all the help... I got lucky!
   / Bending 6" square tubing with 1 side removed #14
Scissors jack could fit in there probably. Might bend it funny though. I liked the suggestion of cutting it and welding inthe desired position
   / Bending 6" square tubing with 1 side removed #15
We need an update, please.
   / Bending 6" square tubing with 1 side removed #16
It would be very difficult to press a pipe into the corner to spread the sides of 3/16" x 14 inches long. Maybe a 1 1/2" solid bar but not a pipe.
Bruce
With a 1/16" abrasive cutoff blades on an angle grinder you could cut a slot 1/8" deep the full length of the 14" corner, bend it open, then weld up the slot and grind the corner round again.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A55302)
2017 Yale GLC050VX...
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55302)
Michelin CARGOXBIB...
2002 Ford F-550 Truck, VIN # 1FDAF56F32EC86522 (A54865)
2002 Ford F-550...
378812 (A51573)
378812 (A51573)
