Thoughts on PTO weight attachment
   / Thoughts on PTO weight attachment #1
1bayouboy
Member
Mount Pleasant, SC
MF GC1710
So I bought a PTO mount trailer hitch receiver. It seem that it could also be a good and fairly simple way to add weight by just buying a 2" hitch
and putting weight on it.....for example just build a box around one and fill the box with concrete and a little rebar. Then just put it into the hitch receiver when I want the ballast on the back. Think this would work..???
   / Thoughts on PTO weight attachment #2
I assume you mean 3 point hitch receiver?
Look something like this? If so then yes it should work fine..
   / Thoughts on PTO weight attachment #4
I see a lot of guys that have a cement block with the male end cemented inside it and they slide it right in to the hitch..
   / Thoughts on PTO weight attachment #5
Concrete weighs about 150 pounds per cubic foot... a 2x2x1 ft block would be 4 cu-ft or about 600 pounds....
You can work out from there how much ballast weigh you may need....
Dale
   / Thoughts on PTO weight attachment #7
And some have gone full three point hitch (or quick hitch)...
Dale
I booked marked that site for future acquisition. I only have the rear mount snow blower at this point so the need for quick hitching isn't pressing, but I can see how that would really be a convenient addition when I have the chipper, hitch receiver and ballast to swap.
   / Thoughts on PTO weight attachment #8
That link to "quick--hitch" is a marketing ploy by web page.... I use a rigid Frame Cat-1 hitch....
I like the BE brand because it uses a different top hook arrangement for adjustment other then the two bolt hook tha everyone needs to modify for clearance...
Dale
   / Thoughts on PTO weight attachment #9
A person could then slide it in the receiver on the truck to move it or for weight!
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
UNUSED WOLVERINE BSH-12-75D BALE SQUEEZE (A57193)
UNUSED WOLVERINE...
John Deere HPX Gator Utility Cart (A55851)
John Deere HPX...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
204158 (A57193)
204158 (A57193)
2008 Ford Fusion Sedan (A55853)
2008 Ford Fusion...
