Thoughts on PTO weight attachment
   / Thoughts on PTO weight attachment #1
1bayouboy
Member
Mount Pleasant, SC
MF GC1710
So I bought a PTO mount trailer hitch receiver. It seem that it could also be a good and fairly simple way to add weight by just buying a 2" hitch
and putting weight on it.....for example just build a box around one and fill the box with concrete and a little rebar. Then just put it into the hitch receiver when I want the ballast on the back. Think this would work..???
   / Thoughts on PTO weight attachment #2
I assume you mean 3 point hitch receiver?
Look something like this? If so then yes it should work fine..
   / Thoughts on PTO weight attachment #4
I see a lot of guys that have a cement block with the male end cemented inside it and they slide it right in to the hitch..
   / Thoughts on PTO weight attachment #5
Concrete weighs about 150 pounds per cubic foot... a 2x2x1 ft block would be 4 cu-ft or about 600 pounds....
You can work out from there how much ballast weigh you may need....
Dale
   / Thoughts on PTO weight attachment #7
And some have gone full three point hitch (or quick hitch)...
Dale
I booked marked that site for future acquisition. I only have the rear mount snow blower at this point so the need for quick hitching isn't pressing, but I can see how that would really be a convenient addition when I have the chipper, hitch receiver and ballast to swap.
   / Thoughts on PTO weight attachment #8
That link to "quick--hitch" is a marketing ploy by web page.... I use a rigid Frame Cat-1 hitch....
I like the BE brand because it uses a different top hook arrangement for adjustment other then the two bolt hook tha everyone needs to modify for clearance...
Dale
   / Thoughts on PTO weight attachment #9
A person could then slide it in the receiver on the truck to move it or for weight!
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A55315)
LMC 2-Row Planter...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
(2) USED 700 LB TRAILER BRAKE AXLES (A57192)
(2) USED 700 LB...
