What To Spray Inside Ignition.
   / What To Spray Inside Ignition. #1
atsah
Elite Member
Maine/Florida
John Deere 3025E
What is the best lubricant to use on the inside of the ignition? I have on hand.
Remington dry lube for firearms.
Silicone spray.
WD-40.
White lithium grease.
Opinions??
   / What To Spray Inside Ignition. #2
"Inside ignition"could mean different places and type ignitions. Be more specific.
Tractor ignition with accessory, glow plug and start. Inside the keyhole..
   / What To Spray Inside Ignition. #4
I don't know what remington dry lube is but if it is dry logically it would make less of a mess.
I have used silicone spray lube in my cars ignition switch.
   / What To Spray Inside Ignition. #5
My first choice would be powered graphite in a puffer tube.
Second, any type of dry lube in a spray can.
I think it's abrasive as well. They do use it but I'm thinking maybe the dry lube would be best so it doesn't get gummed up in the near future?
   / What To Spray Inside Ignition. #8
Of all the lubes I have I use WD40 the most on this type of application.
   / What To Spray Inside Ignition. #9
Graphite is a conductor not sure it is the best thing for an electrical switch ??
I thought we were talking about a keyed ignition switch, not an electrical switch. The graphite is puffed into the key slot. It is what the product was made for.
   / What To Spray Inside Ignition. #10
If/When I spray and ignition switch I use WD-40. Used it on my JD switch when it was starting to fail but ended up eventually replacing the switch. Have also used it on a Craftsman mower the dirt dabbers kept clogging up.
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
DEUTZ MARATHON...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2020 ASV RT65 (A60462)
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
