What To Spray Inside Ignition.
   / What To Spray Inside Ignition. #1
atsah
Elite Member
Maine/Florida
John Deere 3025E
What is the best lubricant to use on the inside of the ignition? I have on hand.
Remington dry lube for firearms.
Silicone spray.
WD-40.
White lithium grease.
Opinions??
   / What To Spray Inside Ignition. #2
"Inside ignition"could mean different places and type ignitions. Be more specific.
Tractor ignition with accessory, glow plug and start. Inside the keyhole..
   / What To Spray Inside Ignition. #4
I don't know what remington dry lube is but if it is dry logically it would make less of a mess.
I have used silicone spray lube in my cars ignition switch.
   / What To Spray Inside Ignition. #5
My first choice would be powered graphite in a puffer tube.
Second, any type of dry lube in a spray can.
I think it's abrasive as well. They do use it but I'm thinking maybe the dry lube would be best so it doesn't get gummed up in the near future?
   / What To Spray Inside Ignition. #8
Of all the lubes I have I use WD40 the most on this type of application.
   / What To Spray Inside Ignition. #9
Graphite is a conductor not sure it is the best thing for an electrical switch ??
I thought we were talking about a keyed ignition switch, not an electrical switch. The graphite is puffed into the key slot. It is what the product was made for.
   / What To Spray Inside Ignition. #10
If/When I spray and ignition switch I use WD-40. Used it on my JD switch when it was starting to fail but ended up eventually replacing the switch. Have also used it on a Craftsman mower the dirt dabbers kept clogging up.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
Adams 16T Tender Body (A56438)
Adams 16T Tender...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
Takeuchi TB016 (A53317)
Takeuchi TB016...
