FOR SALE Condensing Unit Heater
   / FOR SALE Condensing Unit Heater #32
they are very easy to convert from natural to LP gas
   / FOR SALE Condensing Unit Heater #33
Yes I am aware of a kit which I believe just changes the orifice size.
I am considering it but the condensing unit is a fair amount larger than a 'non condensing' style, requires more plumbing, and I am not sure I want that big of a unit in my two car garage.
   / FOR SALE Condensing Unit Heater #34
Yes you can change out the orifices, and a kit for the regulator, or you could just drill the orifices .
Propane burns at about 11''wc nat. gas would burn around 3.5'' wc after going through the regulator in the gas valve
Good thing about a condensing unit is. They use less gas, and can be vented with PVC terminated just outside the wall, or through the roof which is cheaper, and easier than running metal dw vent through the roof
   / FOR SALE Condensing Unit Heater #35
Yeah, I was looking at the install specs to figure best venting scheme. To be honest, the size is bothering me more than the plumbing. I do appreciate the efficiency and I believe the heated air would be dryer, which my tools would welcome.
   / FOR SALE Condensing Unit Heater #36
it should be some larger because of the extra heat exchanger, but it shouldn't be that much larger /taller.
Of course I have no idea of the space requirements for a unit
To say it would be cheaper to operate than propane would depend on nat gas prices vs propane in your area.
Nat sure has the convenience advantage over propane.
Heck, I was in the HVAC business for many years. I don't even heat my garage. 50x80 pole barn would cost me a fortune to heat
Ok I just went back and looked. That is a unit heater /hanging heater, so you would need the head room to install it. It usually hangs from rafter/ ceiling
   / FOR SALE Condensing Unit Heater #37
I have only propane as a choice.
My current shop is my two car detached garage (cars sit outside) with an 8ft ceiling with little insulation. I'm 6'2" and I already have a tall metal storage cabinets on wheels, old kitchen cabinet uppers, metal storage shelves lining the three walls other than the garage door side. Plus I have a JET ceiling mounted air filtration unit.
So, real estate is critical for me. Yeah, I need a bigger shop but my property makes that a challenge without major expense.
   / FOR SALE Condensing Unit Heater #38
I'm also 6'2 240 myself so I know there wouldn't be much room with 8' ceilings.
My attached 2 car garage has 10' ceilings. On my 50x80 16' ceiling.
I have a two post vehicle lift and with my truck in the air. I have plenty of room.
Perhaps you could heat your shop pretty well with a radiant wall heater. It would be a very good option, and They are 100% efficient and take up very little wall space.
I use one for my attached garage in the winter. Keeps the dog cozy
Got to buy a heat lamp to heat the chicken coop tomorrow
Thanks to Dragoneggs for resurrecting this post.
I have installed many unit heaters and the ideal location is tucked into a corner. If I installed in my garage it would go in the same corner where the furnace and WH is now. The furnace is also a condensing type. That area has to be clear anyway. I plan to replace the WH with a condensing on demand unit in the near future also. Last winter my highest gas bill was $90; WH, furnace, and gas range. If/when I need to replace the dryer it will be changed to gas also. Contemplating converting my Gen set to NG also. Love that NG.
If I do not sell it by early spring, I just may and install it anyway. Yes the condensing type is a little larger but this one can be installed close to the ceiling. I think one of the attachments to the post has the size. The install instructions are very complete and any good DIY "expert" should have no problem installing.
Ron
   / FOR SALE Condensing Unit Heater #40
I put it off for a long time, but I finally installed a tankless last yr. So far so good
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
CFG Industrail MX15RX (A53317)
CFG Industrail...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
