Switch Activated Seat Safety Cutoff (2032R)
   / Switch Activated Seat Safety Cutoff (2032R) #1
mikefd
Member
NY
John Deere 2032R
I like my seat safety, sometimes. I think it's an essential safety feature, but it's also annoying. I didn't want to get rid of it entirely, because if I'm brush hogging and I roll the tractor, I don't want to get shredded by the rotary cutter. But, most of the time, I don't want a seat safety.
So rather than disable it, I rigged a switch to turn it on and off on demand:
   / Switch Activated Seat Safety Cutoff (2032R) #2
There are times when the seat switch becomes a nuisance. I was particularly amused with the switch labels!
   / Switch Activated Seat Safety Cutoff (2032R) #3
A thought about safety, maybe it should also have pilot/warning lamp for when seat safety is bypassed...
Dale
Dale
Yeah, that's the plan, when I find a good illuminated rocker switch.
   / Switch Activated Seat Safety Cutoff (2032R) #5
If anything ever happens where your attention to and the importance of safety is ever questioned in court . Your advice and video will hang yourself .
You mean I won't be able to sue myself if I get killed because the tractor is still running? I will try to live with it.
   / Switch Activated Seat Safety Cutoff (2032R) #7
:thumbsup:
I have done somewhat the same, with a switch which will force the tractor to start (turn over) and a switch to disable the safety gear when running. Normally these switches are off and located in a covered box, so that all the safety stuff works as designed.
This has been a pet peeve of mine for years. Before retiring, we farmed and start problems because of safety switch malfunctions was a real problem. If the manufacturers of these machines feel that these designs are so necessary, then the engineering solutions should be almost bullet proof, and one of the last things to malfunction. To do otherwise invites the owners to do as documented here and above.
   / Switch Activated Seat Safety Cutoff (2032R) #8
Someone trying to rescue you could certainly sue you.
   / Switch Activated Seat Safety Cutoff (2032R) #9
:thumbsup:
Manufactures have been sued since that woman laid the fuel cap/fuel gauge over the battery terminals on a JD 110 garden tractor . Manufactures have to worry more about lawyers than the owners .
   / Switch Activated Seat Safety Cutoff (2032R) #10
my GT is disabled too. I always turn off the pto if I am mowing when i stop. but damned if i am going to wear out the starter every time i find a dog toy to move out of my way!
Ok, let's do this. On what grounds? Spell them out please. I will respond to every point like it's a notice of complaint and I'm filing my response in court.
   / Switch Activated Seat Safety Cutoff (2032R) #12
All you self destructive people better hunker down, the safety police are about to descend on you (us)
We must stand together against this evil!
   / Switch Activated Seat Safety Cutoff (2032R) #14
I keep my safety switch intact for the reason it could save the engine if I tip my tractor over. I'm not sure if have the presents of mind to reach down and turn the key off if I'm on my side. I plan on living after a tip over and will need the tractor after that.
I respect your right to make choices that are right for you! As we all should.
   / Switch Activated Seat Safety Cutoff (2032R) #16
you could also put a timer on it to go back to safety mode after it timed out that way you wouldn't forget to, still install a lighted switch to tell you if it was on or not
   / Switch Activated Seat Safety Cutoff (2032R) #17
Could you use a mercury switch to shut it down when it reaches like 45 or 60 degree tilt ? One switch to turn off the seat safety and a Mercury switch in case you tip her over.
Neat idea!
Whoah! That's a great idea! I'm looking on amazon for mercury switches.
As for the illuminated switch, that's more for fun than anything else. I know what position the switch is in because of the labels I used.
   / Switch Activated Seat Safety Cutoff (2032R) #19
I did the same thing on my tractor. It seemed like it always stayed in the off position. I never found the task where I felt like it was an essential safety feature.
   / Switch Activated Seat Safety Cutoff (2032R) #20
I have plans for something like this myself. My situation is always the "visual" thing. Even though I have experience driving a forklift, I found out right quick that running forks on a tractor on uneven ground is nowhere near the same as a forklift on smooth concrete. :) I'd like to be able to stand up to see. Sometimes would be nice for bucket work as well as I'm not real experienced with my bucket. Thanks for making the video.
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
500BBL WHEELED...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
