40 Acres, Steep!, 1 Mile Road; Need Advice
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #141
I wouldn’t waste my time using a grapple to do something pallet forks would be used for like unloading something from a truck or trailer that was loaded with a fork lift. That is exactly what they are for and the grapple isn’t even a close second to it.
3 point mounted forks are for many a waste as they can’t even reach the back of the truck to unload a pallet and in many cases they would have a hard time unloading a trailer that had to be side loaded at lets say a stone yard where the lift had no way to drive onto the trailer. Believe me this happens more that most realize.
Backhoe for some is waste for some it’s a god send.
Take the time to think it threw and make the right decision for you.
For me it would cost more to rent when I want one here than it did to simply buy one.
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #142
Better check if it's legal for you to do your own septic before you buy a backhoe. I had ambitions of doing that here as well. About 2 years before I was going to do it, they changed the local laws in the county so now only licensed installers can do the work. :rolleyes:
Thanks mossroad, I'm lucky in that it's totally legal in my county to install your own septic. Appreciate the caution though, and a good lesson for all.
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #144
Of course, I could probably study up, take the test, pay the fee, and become a licensed installer for less than the cost of having it done, but sometimes ya just gotta ask yourself "Is it worth it?" :confused3: ;)
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #145
I did much of the install of mine but had the assistance of an experienced installer just to keep me from making any major mistakes.
Did have him cut the laterals since depth and slope were critical.
Even though I have a full size backhoe it was much faster to do with an excavator (which my buddy has so that was pretty convenient. With a full size excavator we trenched 450’ of tight line, 2 tanks (one 1000 gal and one 1500 gal), 500’ of laterals and the distribution network in one afternoon-would have taken significantly longer with my backhoe.
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #146
Thanks reg, good post :thumbsup: I have been considering waiting on the backhoe to save cost. I think it would be so darn useful, but they sure are expensive. I feel like putting in the septic justifies a chunk of the cost, but renting would save more $ on the project. Would also like to add culverts and I hear they can be useful for building rock walls. Would be nice to not have to rent and might find more uses in the future, but they add such cost... I imagine most users here would suggest buying with the original purchase as I see a lot of uses for it. Not decided yet I guess, will have to think about it more.
Waiting on the snowblower, will see after trying with the back blade.
Sounds like I should add grapples and forks to the purchase. Wasn't planning on those at first, but seems like I may regret not having them.
One way to compare tractors is to separate the things that should be included with a tractor purchase from those that make no difference if they come with the tractor or not.
With a basic tractor, bucket, and blade you are going to learn so much in the first few months that your decisions on the implements will be different from what you think now. There's a learning curve.
It is hard for me to see any advantage to buying certain things at the same time you buy the tractor. Instead of buying, you could simply make a list of things that could be added anytime without penalty: lights, wheel weights, backhoe, extra buckets, grapples, and forks would be on the "later" list....and lots else besides. Since you are going to buy new from a dealer, you can just hand him that list and say that when he has an incredible used deal on one of those items he should give you a shout.
On my own list of basic decisions I needed to make on the tractor itself last time I bought new were: HP range, transmission type, cab or not, FEL bucket type, tire type, SSQA, type II 3pt?, and some combo of front and rear remotes. Then warranty & financing. The rest can wait.
As a for instance, look at some of the backhoe decisions: Hoes basically come in three types depending on how they are mounted and you haven't yet used any of them enough to compare them - but you will. There is the 3pt mount, the add-on subframe mount, and the integral (TLB) mount. AFAIK, only Kubota and big commercial machines make the integral-mounted type and if you not considering those brands, you are probably looking at one of the first two types of hoe. But which one? BTW, not all backhoes swing a full 180 degrees and that's important.
Think about this, When digging, you'll move the tractor & hoe a lot - a lot more than you think now. Can you do that from the backhoe seat via some crawl feature? Or does it require raising the stabilizers, releasing brakes, getting down from the backhoe seat and going around to the tractor seat to move it a few feet? Of course you don't know....and my point is that these are all decisions that can wait.
As to how backhoes are powered, some are PTO powered and others are driven by the tractor hydraulics. You'll have a choice of buckets in width, depth, and teeth, plus pin-on versus quick attach, and does it get to have a thumb or not? Hydralic or manual?
If you are in an area where you an put in your own septic I'd be very surprised if you can't save enough to outright pay for a nice backhoe. But it can come later.
rScotty
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #147
I bought my back hoe LARGELY on impulse, PARTLY on opportunity.
The company (American Jawa ?) that re-badged Kukje tractors as "Century" was going out of business and I was making fairly frequent trips to their area.
I picked it up (in a somewhat "soiled" horse trailer, having just dropped off some horses) on my way back through Harrisburg, PA.
As I recall $5K for what was in essence an Amerequip 8 1/2 ft hoe with 18 and 24 inch buckets.
It has been good, but hasn't seen as much use as I anticipated.
BTW I unloaded it from the trailer and was able to install it single handed.
Only tip on that is to assemble everything and only tighten bolts enough to bring parts together, get it onto the tractor and "exercise" the hydraulics through the full range of motion. That gets it all aligned with the loader and back hoe sub frames agreeing with each other - THEN tighten everything down to spec.
On a different trip I got a full set of turf tires and wheels, also at a substantial discount from list price.
If I had to start over I would call local excavators and landscapers for quotes on everything I have done with it.
The informal "ADVICE" that can be garnered from free quotes can be HUGELY valuable.
An experienced operator will question if you "really want to do that ?" or "wouldn't it be better to berm here and swale there".
(sort of thing).
Then they can do it in a lot less time and at lot less risk to life, limb and equipment.
WRT a septic; I could do it, but it would take a lot of "think it through" to do SAFELY and preserve access for the tank and pipes to be installed.
It isn't the "just dig a big pit" project it might appear to be.
BTW (again)
Another vote for loaded rear tires - and I'll add that R4s have more VOLUME than equivalent Ags, probably 50 - 55 or so gallons per tire for the Branson you are considering vs about 35 gallons for the Ags.
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #148
@Pugemasta- can you remind us why you'd prefer an HST? I think with your steep grades a geared machine (power shuttle perhaps) would be a better fit.
I'd like to add my vote for the SSQA (vs pin-on bucket). It makes the loader so much more useful/flexible. If you're building a house, having pallet forks will be super helpful for unloading delivery trucks, setting trusses, landscaping, etc. A bucket is a must have and the ability to swap the bucket for something else (even if you don't own it yet) is not far behind.
You may also consider Kioti. They offer a number of machines ranging from 25->100HP. I would think there'd be something in that lineup (DK5510 or NX5510 HST) that might offer some comparison- if you have a dealer nearby.
As the owner of a pin-on who has quite a few hours in using tractors with the SSQA, I would definitely vote for the SSQA. I have forks for my Ford, but it is a pain to swap over so I don't do it unless I have to have the forks for a job. In my opinion the little bit of extra capacity you would gain with the pin-on is of no practical consequence for most people and is far outweighed by the versatility of being able to quickly drop a bucket and pick up another universal attachment.
Thought I'd mention that I'm planning to treck a bit further today and check out a kioti/TYM dealer. Quick look online revealed the DK6010SE, has mid PTO option leaving open the possibility of a front snowblower. Also the NX series, not sure if it's out my price range or not though. Looks like the t554 might be an option as well. Someone, can't remember who, recommended I look at kioti on here. Any thoughts on those brands or models? let me know :D
   / 40 Acres, Steep!, 1 Mile Road; Need Advice #150
IMO, pretty much all the tractors built today are pretty nice machines. :thumbsup: All a bit different in one way or another. All pretty much have the same capabilities as long as you compare apples-apples and not apples and oranges. You just need to find the one that fits you best.
Yes some have different or more thingies and do dads which can make operating easier and nicer, but the actual capabilities are fairly close. Find the best one that fits you and your circumstances.
Have fun while you're looking-researching, the "real" fun is yet to come. ;)
2025 INDUSTRIAS AMERICA FT510 5'X 10' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2020 Chevrolet Silverado Pickup Truck, VIN # 1GCRYDED7LZ290322 (A51572)
2020 Chevrolet...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2014 Chevrolet Silverado 4x4 Pickup Truck, VIN # 1GC1KXEG9EF156183 (A51572)
2014 Chevrolet...
