County Line Post Hole Digger - Watch which one you get!
   / County Line Post Hole Digger - Watch which one you get! #1
flashpuppy
Triad, North Carolina
Kubota M7040 Kubota SVL75-2
Careful which one you get from the lot. Check the welds before you take it home. Lots of porosity here. Dang tab was almost broken off after three holes.
9D2FBBEF-3E89-4EEC-8574-3FBD258101C8.jpeg.
Chinese fabrication at its best.....
Dale
I know... It is my own fault. Got in a pinch and needed one like yesterday so I just ran to TSC after calling to all my local dealers looking for one.
   / County Line Post Hole Digger - Watch which one you get! #4
How do these hold up to a 70HP Cat 2 tractor? I need one but don't know whether I should spend the extra and get a Land Pride/Everything Attachments or the TSC brand?
   / County Line Post Hole Digger - Watch which one you get! #5
Ya get what ya pay for. For your tractor, look for a unit that has a gear ratio in the 4+ to 1 ratio range. That way you are pretty much sure that you have a good heavy duty unit. Not cheap though unless you find one used.
So far... it has survived behind my M7040. I’ve probably lost half a dozen shear bolts and I haven’t dug at above idle.
It took some tightening up of all the movable points. Changed the “hoop to boom” pivot pin to a bolt with washers between all surfaces. Allowed me to tighten that up and take a lot of sway out of it. Cinched it down really tight, then backed off a quarter turn. Jam nutted the bolt to keep the tension I put it at. Seems to have helped a lot. I also put some washers on the top link connection to remove the side to side slop.
I am about 24 holes into an 80 hole project. If it survives, then I guess it did okay. Even it doesn’t survive, it was worth $10 a hole to not do it by hand. I definitely am ordering a post driver before I start on the other 500+ holes but this will get my fence up before the weekend.
   / County Line Post Hole Digger - Watch which one you get! #7
That's too bad. That is one ugly weld. I would take the unit back and exchange it.
Just bought the same one myself and all the welds looked great and I was impressed. Good value IMO.
   / County Line Post Hole Digger - Watch which one you get! #8
My County Line Digger has had a few problems and as far as I know every one of them has been my fault. I'd buy one again in a heart beat. I use it on a 60 HP tractor.
   / County Line Post Hole Digger - Watch which one you get! #9
I suggest: ...Steer clear of the TSC brand!
   / County Line Post Hole Digger - Watch which one you get! #10
I'm sure you have valid reasons but I don't agree. I dug 45 holes today with the County Line 3pt PHD. It worked flawlessly. I have seen a number of others and don't see anything to warrant the product costing twice as much.
15200 (A56857)
15200 (A56857)
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
