Easiest way to change hitch ball sizes
   / Easiest way to change hitch ball sizes #11
I have a TC45 w 2-5/16 hitch on my drawbar.
I want to also be able to pull my splitter which has a smaller ball. I need an inexpensive way to switch hitch balls back and forth
If the splitter is the only thing with a different ball size, you might consider changing the coupler on the splitter tongue to take the larger ball.
   / Easiest way to change hitch ball sizes #12
Get one of these at HF store or most any hardware store and weld it to your draw bar. Then you can use a triple ball hitch. Total cost about $40. for receiver and tri ball.
   / Easiest way to change hitch ball sizes #14
I thought about that for the OP as well. However, if he welds that to the drawbar, he won't be able to pin things to the drawbar anymore. If he just matches one hole on the triple ball hitch on his existing drawbar, then drills a matching hole to the second hole on his existing drawbar, he can then just pin the triple ball hitch to the drawbar when needed, and remove it when not needed. No welding required and maintains the existing drawbar for other uses. He could also rotate the triple hitch 90 degrees and drill one hole through that axis, too, so he can use all three balls. Heck, he can get the triple hitch with a hook on it, too, like this.
I added some red circles as to the two holes I'm talking about. Just make sure they line up with the 2nd holes on the existing drawbar.
The OP is interested in pulling a woodsplitter,, not a Fruehauf 53 foot reefer full of ribeyes ,,,
Heck, he could almost hold the hitch in his hands to move the splitter,, the 3 point should be fine,,,
You get my situation exactly. In fact I have moved my splitter several times by hand with the caster down. I am tired of that and I can’t get it where it needs to go this time out.
I will not buy a 3 point setup because that is expensive and heavy and ties up those attachments.
The receiver that adds to the drawbar is interesting. I have hitches for the truck and I can use those. If it’s added on top of the drawbar it will help level the trailer a bit more.
Thanks, David
   / Easiest way to change hitch ball sizes #18
He could still use the receiver I mentioned and just insert a hitch without a ball and use the hole in it as a drawbar for other attachment equipment. There's many ways to skin a cat.
As CADplans mentioned he could mount a ball in this type of 3 pt. bar to tow his splitter. I'm sure the splitter has enough tongue weight to keep it from raising the 3 pt. arms.
   / Easiest way to change hitch ball sizes #20
If he mounts a ball on the center of that hitch, he'll have to either mount more balls offset from center (probably no big deal at low speeds), or remove the ball and install the other if he wants to maintain center (again, probably no big deal with a log splitter).
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
More info coming soon! (A55787)
More info coming...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
