What to ask for my B 9200?
   / What to ask for my B 9200? #1
Mikefromcny
Upstate NY
White 2-65, Kubota B9200
Hi all, thinking about upgrading my tractor. It is a 1993 b 9200. 1070 hours. Ag tires. 4x4. Power steering, 3 range gear transmission.
Everything works great on it, right down to the lights. Looks pretty good, but could use a good cleaning.
BF350 loader
4572 backhoe
4' rototiller
4' brush hog
5' finish mower
5' back blade
6' york rake.
Everything is in good working order.
I saw a jd855, loader, front mount snowblower for $11k, which seemed a little high, but maybe not.
I've also never sold a big package like this either, but depending what I could get out of it would determine what I could upgrade to, or if I should just keep what I have.
What do you think?
   / What to ask for my B 9200? #2
Sounds like a nice package for someone.
   / What to ask for my B 9200? #3
If what you are upgrading to is dependent on how much you can get for everything, then you might want to consider selling the attachments separately. A bit more effort involved, but you’ll make a lot more money.
Do you need to upgrade to a larger tractor, or do you just want to try out something different? It looks like you’ve done a good job acquiring attachments that are well fitted to your current tractor. Plus your B9200 is a known quantity from a maintenance standpoint. There’s a lot to be said for that.
   / What to ask for my B 9200? #4
Agreed, Driver.
OP should realize more if implements other than FEL and (probably) BH sold separately, though will take more effort and time.
SDT
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
CAT 930M (A58214)
CAT 930M (A58214)
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
