Will This Compressor Inflate My Tractor Tires?
   / Will This Compressor Inflate My Tractor Tires? #1
keegs
The County, ME
Kubota M5640SUD
Hi, I have a Craftsman 125 PSI 3 gallon air compressor. Is it capable of topping off my tires? I have a Kubota M5640.
Thanks
   / Will This Compressor Inflate My Tractor Tires? #2
yes, I only run around 12# of air in mine
   / Will This Compressor Inflate My Tractor Tires? #4
Yes but it’s going to take a while. I recommend running the fronts at max pressure and leaving the rears alone unless there’s a problem. You don’t want the rear tires inflated more than necessary because they ride better and have more traction at lower pressures.
   / Will This Compressor Inflate My Tractor Tires? #5
It will take forever due to the volume of air needed, but it will fill.
Thanks Man... I think I'm noticing low pressure in the rear tires. The tractor is 6 yo and I haven't even put a gauge on them. I'm planning a number of scheduled maintenance tasks for spring.
   / Will This Compressor Inflate My Tractor Tires? #7
Thanks
When I filled the tires on my Ford I used my little HF 1 gallon compressor to air them back up. I had plenty of time to work on other things while it was pumping, but it got the job done. If I were filling them completely with air I would have had to roll out the big one.
   / Will This Compressor Inflate My Tractor Tires? #8
I have a 5 gallon/125 PSI Craftsman air compressor. Its worked just great for me for 30+ years. I run just enough pressure in the rears to get full bar contact across the entire rear tread - about 16 PSI. Run max pressure in the front tires.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
1840 (A51248)
1840 (A51248)
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A55788)
2006 Mack CT713...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2016 Peterbilt 567 Tri Axle Dump (A47477)
2016 Peterbilt 567...
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
