grey goose
I use a B2759 snow blade. Finishing up my work during the last snow event, I discovered the plow would no longer pivot from right to left. Backing up, I noticed a pool of hydro fluid under the blade. Climbed out to investigate and discovered the DA cylinder end cap had blown out. After pulling the cylinder, I found damage to the end cap and the cylinder. Also, one end of the snap ring was broken. [see photos]
Best guess, gravel got lodged between the cylinder mount and the end cap, and when the angle was reversed, it was driven into the end of the cylinder causing the damage seen in the pictures.
I've got little experience with hydraulics so, my question is: can this damage be repaired, or must I replace the cylinder?
Initial research shows a replacement Kubota cylinder costs $525. I'll explore after-market sources Monday, and will bring the cylinder to some local shops for estimates.
Has anyone else experienced this sort of failure? Is there anything I can do to prevent a repeat? Thinking of cutting a piece of pipe insulation or pool noodle to place on the cylinder rod to keep out debris. I'd welcome any other ideas or suggestions. TIA!
