atsah
Elite Member
That looks way better.. I always turn the pto off before I lift it, just a habit..
I took the tractor out after all those adjustments and it worked great blowing snow. I have another issue with breaking the shear pins, but I cannot hang that on Woodmaxx. Apparently the hydraulic control which is being used as the top link control, in the summer time is used at the flow on control for my backhoe. So when I put it in a forward or reverse position, it stays on and rapidly moves the top link up or down at a rapid rate depending on which direction I am pushing it. I think that rapid movement of the top link while the blower is going is contributing to the breaking of the shear pins. So for now, I am training myself that if I want to move the blower up or down; or in or out, I need to turn down the rpms, and disengage the pto FIRST, and THEN move the positioning. I think that will work for now.
I had the same problem with the hydraulic rotation being too fast in mine. Search for a 1/2 NPT flow restrictor fitting. It solved my problem and makes the rotation speed much slower and manageable now. You only need one restrictor. In this pic it痴 the black fitting on the middle remote.
On your point 5- that top link shouldn稚 need much adjustment at all- once it痴 set. Most blowers don稚 have an adjustable top link and do just fine- set it and don稚 mess with it. If it does move too fast add a little flow restrictor to the circuit- it will slow things to the speed you want.
My new FitRite TnT cylinders came with integrated restrictors. Think the ones on my old machine had restrictor fittings. At any rate, they are so nice for slowing things down & getting precise control.I had the same problem with the hydraulic rotation being too fast in mine. Search for a 1/2” NPT flow restrictor fitting. It solved my problem and makes the rotation speed much slower and manageable now. You only need one restrictor. In this pic it’s the black fitting on the middle remote.
Did you mention you had a top and tilt before all this??????
The top and tilt does not have a float position to let this thing work properly, that is why you need to reinstall the threaded top link and buy hitch.
Disconnect the top and tilt and remove it and reinstall the top link and a new quick hitch and you will be better off.
