Woodmaxx Snowblower Shear Bolts?
   / Woodmaxx Snowblower Shear Bolts? #51
That looks way better.. I always turn the pto off before I lift it, just a habit..
   / Woodmaxx Snowblower Shear Bolts? #52
On your point 5- that top link shouldn’t need much adjustment at all- once it’s set. Most blowers don’t have an adjustable top link and do just fine- set it and don’t mess with it. If it does move too fast add a little flow restrictor to the circuit- it will slow things to the speed you want.
   / Woodmaxx Snowblower Shear Bolts? #53
I took the tractor out after all those adjustments and it worked great blowing snow. I have another issue with breaking the shear pins, but I cannot hang that on Woodmaxx. Apparently the hydraulic control which is being used as the top link control, in the summer time is used at the flow on control for my backhoe. So when I put it in a forward or reverse position, it stays on and rapidly moves the top link up or down at a rapid rate depending on which direction I am pushing it. I think that rapid movement of the top link while the blower is going is contributing to the breaking of the shear pins. So for now, I am training myself that if I want to move the blower up or down; or in or out, I need to turn down the rpms, and disengage the pto FIRST, and THEN move the positioning. I think that will work for now.
I had the same problem with the hydraulic rotation being too fast in mine. Search for a 1/2” NPT flow restrictor fitting. It solved my problem and makes the rotation speed much slower and manageable now. You only need one restrictor. In this pic it’s the black fitting on the middle remote.
I had the same problem with the hydraulic rotation being too fast in mine. Search for a 1/2 NPT flow restrictor fitting. It solved my problem and makes the rotation speed much slower and manageable now. You only need one restrictor. In this pic it痴 the black fitting on the middle remote.
Excellent Idea!!! I'll get one
On your point 5- that top link shouldn稚 need much adjustment at all- once it痴 set. Most blowers don稚 have an adjustable top link and do just fine- set it and don稚 mess with it. If it does move too fast add a little flow restrictor to the circuit- it will slow things to the speed you want.
You know..... I must be one of those guys "who don't get it" about the drafting part of the operation of the 3 point. When I raise and lower the 3 point, everything gets all jacked around. It's hard to describe, but basically if I move it up or down, the relationship of the box to the tilt changes. So just by touching the raising and lowering arms, everything changes.
One of these days I will get someone to explain to me what the TWO levers do in tandem that raise and lower the 3 pt attachment. I just use both of them together because I haven't figured out what they do separate from each other..... call me confused....
   / Woodmaxx Snowblower Shear Bolts? #56
My new FitRite TnT cylinders came with integrated restrictors. Think the ones on my old machine had restrictor fittings. At any rate, they are so nice for slowing things down & getting precise control.
You may need to modify some impliments, especially older ones. But when everything is QH compatible & you have TnT, it's so easy to hitch up an impliment. I can hitch up to a crooked off kilter impliment in under a minute without getting off the machine if there is no PTO shaft or hydraulics.
   / Woodmaxx Snowblower Shear Bolts? #57
Did you mention you had a top and tilt before all this??????
The top and tilt does not have a float position to let this thing work properly, that is why you need to reinstall the threaded top link and buy hitch.
Disconnect the top and tilt and remove it and reinstall the top link and a new quick hitch and you will be better off.
   / Woodmaxx Snowblower Shear Bolts? #58
Looking at the pictures I think that is a tilt, that’s a problem.
   / Woodmaxx Snowblower Shear Bolts? #59
That is why I told him to remove it and reinstall the original top link and purchase a quick hitch and be done with it since
the top in tilt is only adding to his problems.
Why would the hydraulic top make a difference (and tilt)? If I just set it at a position and leave it be? My big problem is the draft levers. Can someone explain to me which of the draft levers to use or not use. That is what messes me up when I lift the 3 point.
On my next trip to Reno, I will stop at Harbor Freight and get their QH to see if it makes a difference. I think I have a manual top link around here somewhere.
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2000 Ford F-450 Service Truck (A51692)
2000 Ford F-450...
2004 BMW Sedan (A51694)
2004 BMW Sedan...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
