Todays shop time.
   / Todays shop time. #801
4570, what do you do with the bullets? Take them out and patch, and if so, with what?
or is this built in "distressing"?
   / Todays shop time.
On the previous 2 bullets I hit I ripped it narrower to cut out the bullet. On the last piece you won’t be able to see that edge in the finished piece so I left it alone. They would have made a cool conversation piece but this table is going in an upscale office so I don’t think the bullet would be a desirable trait.
   / Todays shop time. #803
I thought it would have looked pretty neat...
I could use a hand with some suggestions on how to get this pulley off my rototiller.
It's so large that my pullers won't fit. New trans/axle assembly going in, drops down, not up so pulley
won't clear, has to come off. Has a keyway.
Does one just take a block of wood and gently persuade it?
What do you use when you don't have the right tool?...
thanks
   / Todays shop time. #804
I've used this HF bearing separator for a lot of awkward things. The pieces are easily adaptable to use with longer bolts or rods or just heavy flat bar drilled where necessary.
   / Todays shop time. #805
How about drilling two holes equally spaced from the centerline of the shaft and opposite each other through the pully then using suitable bolts, nuts, and washers affix your puller.
If possible, the application of some heat might expand the hub enough to get things moving.
Reassemble with a slathering of antiseez compound to insure EZ disassembly in the future.
Does sound like a good excuse to purchase a bigger puller however, as the guy who dies with the most tools has the best auctions.
B. John
   / Todays shop time. #806
Clean/chamfer the end of the shaft a bit first
You might try a tie rod tool or pickle fork on the backside. It LOOKs like there may be enough room. Might be enough to break it loose then continue with a wooden block or spacers and the wedged pickle fork.
   / Todays shop time. #807
thanks guys, going to use a little heat and see if I get lucky.
pickle fork and wiggle wiggle wiggle....
if not, trip to Napa for an expensive tool I'm sure.
   / Todays shop time. #808
This/\/\/\ and patience.
I had a similar problem on a mower pulley that I could not get off or access.
I first doused it for about a week with loose juice and then
heat, a tapered block of wood and a hammer was the only "wrench" that would fit.
I pounded the bejeesus out of it and it finally gave up.
   / Todays shop time. #809
Plan B
Perhaps you could borrow a puller. I’d be happy to help but not really up to a road trip. Lol.
   / Todays shop time. #810
Drew, I think some auto parts places will loan / rent pullers and such.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
(2) LOAD RATCHETS FOR DTAKE POCKET (A52708)
(2) LOAD RATCHETS...
2008 Dodge Ram 1500 Pickup Truck (A55973)
2008 Dodge Ram...
