Comparison Which manufacturer has the highest HP true HST tractor?
   / Which manufacturer has the highest HP true HST tractor? #11
AS LouNY said, you will have a hard time to find agricultural tractors 60+ HP with HST it is not robust enough for that, but you'll find KVT in the case of Kubota or CVT in other makes or PS (power shift)
800+ hp dozers run HSTs. It's not that they aren't strong enough. It's that bigger than CUTs efficiency matters a bit more than convenience. Bigger machines tend to be ag machines rather than utility machines.
   / Which manufacturer has the highest HP true HST tractor? #12
I was under the impression that most of them where 3 or 4 speed automatics or power shift transmissions.
Which ones are hydrostatics?
   / Which manufacturer has the highest HP true HST tractor? #13
Many large Ag tractors are Infinitely Variable. Probably not oil driven. Too much heat and hp loss. Not to mention noise!
   / Which manufacturer has the highest HP true HST tractor? #15
Ya, good article. It's from 2007, so not exactly a recent development either (regarding lots of HSTs in big machines). The downside to HST has always been cost/complexity & efficiency.
Sometimes it's worth it (big time for CUTs) when precise control & manuverability is paramount. Sometimes not (big ag tractors) where they just pull a huge plow or impliment in circles all day at the same speed.
I think the current crop of CVTs is closing in on the efficiency of geared machines while still giving the control of a HST. I havent seen any in the CUT market yet, but I believe there are a handful in the UT range. Not sure what the price premium is, but I bet it's a bit as essentially you have a small HST ontop of a geared transmission that's more complex than a clunker 3 speed on every HST (at least in the CUT range).
   / Which manufacturer has the highest HP true HST tractor? #16
The noise must come from bad design, larger equipment with hydrostatic drive dosent whine like microtractors, know only one Kubota BX and the noise is very unpleasant.
   / Which manufacturer has the highest HP true HST tractor? #17
Fendt 207 Vario has the best transmission there is, stepless from 0.02 to 40km/h but not particularly cheap to buy.
..And all the way up to the 1050 Vario with 500hp.
   / Which manufacturer has the highest HP true HST tractor? #18
Yes, Fendt is very popular here I live.
   / Which manufacturer has the highest HP true HST tractor? #20
you wont find one in the 60hp range as far as pto HP is concerned
2017 Ford E-450 LP Handicapped Bus (A53422)
2017 Ford E-450 LP...
2014 Ag Spray Schaben Sidedresser (A57024)
2014 Ag Spray...
CATERPILLAR D6N LGP CRAWLER DOZER (A52707)
CATERPILLAR D6N...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
24628 (A55853)
24628 (A55853)
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
