Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
At least you have a good sense of humor.
The math (if you like math) is the easy part. Its actually understanding the concepts and how to apply the math that give most people fits.
I like it all. I'm a designer/draftsman by day, and a jack of all trades in my free time, so being able to apply math to solve real world problems is fun for me. Crazy, I know. And what is life without a sense of humor! :dance1:
I was actually thinking about modeling up a simple representation of this in CAD and running an analysis on it that way. That would be the ultimate, but would be overkill for this.
I might go ahead and rerun my scale test though, when I get time, being extra careful to keep everything in line, even, and vertical.
It would be nice if the real world testing approximated the theoretical force curve and values more closely.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #22
Wouldn’t it be a lot easier to figure out the ratio between the distance the loader pins move and the cylinder stroke? That method would fail to account for it being stronger at the bottom and would instead give an average. And you’ll need to know the psi the tractor is putting out.
Correct. It dont account for being stronger at the bottom. But does give a good average value for what the loader lifts.
Does your loader manual have a lift curve?
No. My comment was just in reference to an earlier reply about loader lift curves being more parabolic in shape and without the flat spots my original test showed.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #24
Here's a typical curve:
No problem.
But the critical key is cylinder bore diameter. Cause without the MFG spec, its difficult to measure without guessing.
I am betting 40mm bore
You were right to guess 40mm.
Here are the measurements I took tonight.
The relief pressure was listed in the manual.
I ran a few calcs (on the right) but I'm not sure where to go from there with calculating the forces.
It's been a few years since my statics and dynamics classes in college and I'm afraid I've forgotten a lot of it. :-/
Thanks for the help!
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #26
Interesting exchange of information. Great to see everyone engaged and contributing. Don’t want to get involved in the discussion about whether tests are done scientifically or not. The key thing we’d like to say with regards to lift capacity is that you can fill the bucket with gravel and dump it at full height. Pretty much all anyone needs to know other than the tractor is a system, and max lift capacities are often measured in consideration of the whole system. The loader can lift more than spec, but will put stress elsewhere putting other areas and safety at risk. Be careful out there, stay within practical limits.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #27
The first step is figuring the angle in which the cylinder's force is applied.
This isnt the angle with the ground, or any particular point that is easily measured. Thus the triangle measurements is all aI need. Knowing the Lengths of the 3 sides I can calculate the exact angle. (look up law of cosines for formula)
So we want to focus on triangle BDC, and in particular...we need to solve for angle B. And then EDC (when raised) to again find the angle of the cylinder
Law of cosines is a PITA to actually type out. I'll trust you can apply the numbers on your own and solve for angle B and E when raised? if not I can attempt to spell it out.
I come up with 21.08 degrees when lowered and 15.3 degrees at full raise.
________________________________________________________________________________
Step 2....Find the force of the cylinder.
40mm bore @ 2205psi = 4295 pounds of push force PER cylinder.
But cylinder mounted on an angle. To account for that, the vertical component of the lift force is the Sine of the angle.
So. Sin(21.08) x 4295 pounds x 2 cylinders =3090 pounds vertical force
....Sin(15.3) x 4295 x 2 = 2266 pounds vertical force at max lift
_______________________________________________________________________________________________
Step 3: The above is the lift force where the cylinder attaches to the loader. Now we need to figure how that relates to the Pin location
Now it becomes a lever......A-B-C with C the fulcrum, and B where the force is applied......At point A....you have 0.539% of force applied at B.
So at ground level, 1665#
At max height, 1221#
______________________________________________________________________________________________________
Step 4. This is a bit tricky to "actually" measure. Especially without a force gauge. And that is Just how much does the weight of the loader/bucket take away from the capacity? IT can be measured with a pressure gauge and reverse calculated. But given the "spec" is 947# to max height....and the cylinder force NOT accounting for the weight of the bucket/frame is 1221#....I'd say that's pretty close.
I definitely appreciate and heed the practical limits, but at the same time I like to understand and over-analyze everything. Guess that's just the designer/engineer in me.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #29
Wow, thanks for all that!
A couple of questions, both regarding Step 3:
1.) Did you mean 53.9% (aka .539)?
2.) For the ratio of the 2 levers, I agree that the C-B distance should be used, but shouldn't we be using the C-A distance as the length of the overall lever? (Instead of using the sum of C-B & B-A.) That would be the true radius, would it not? This would change the 53.9% to 55.4%, which in turn would increase the results slightly. 1712# & 1256# respectively.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
TROY-BILT TB4216 CHAIN SAW (A51248)
TROY-BILT TB4216...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
