Okay guys... So here's the latest update after tackling what I could last night.
It's definitely not wheel or hub related. Lugs on both sides were impressively tight. With the rearend on stands, I can rotate the wheels around. The passenger side is definitely the culprit. I removed both wheels to have a closer look. Now, with or without the wheels I can spin things around until about the 359° mark and the passenger side COMPLETELY LOCKS UP. If you roll it back just a smidge, it will unlock and spin around another 359°. If you go past the "locked" position and spin it back around, it will again lock in the same position. Also to note... the passenger side shaft has MAJOR slop in that 360° mark. I can clunk it back and forth about 3/8" in either direction before affecting the other hub on drivers side.
So, assuming the basic setup is like any other live axle rear end, it should be a ring and pinion?
Ernie says, Pray it's not the ring & pinion.... I'm pretty certain without splitting her open, that it's going to be a missing tooth. I'll be honest here guys. I'm right in the middle of 2 major home projects (failed 51yr old septic replacement & also clearing a 2 acre overgrown pasture). As you can see both would be 100 times easier with the tractor, especially because I have a backhoe on mine. Without it, they'll be more expensive and way more labor intensive. I paid $4500 for this thing. Is it worth it to have her repaired (cost alone) and is this a do it yourself job? Are the parts even available? Hoye Tractor doesn't show any ring & pinions.
Opinions much appreciated! Thanks guys
