Fuel Pump Frustration
   / Fuel Pump Frustration #11
radios1 is correct, its 1/4 pump, it should do the trick, there should be a small fuel filter installed b4 fuel enters the pump like a baldwin bf840 if u got foam its not the pump doing it, your sucking air
   / Fuel Pump Frustration #12
OP is your fuel filter before or after the pump? If it's before there is no need for the addition of a small pain in the neck filter that will need replacing..
   / Fuel Pump Frustration #13
Radio, that's 5-9 psi.. if the 4-7 is "to much" fuel, the poster isnt doing any better..
Sounds like a 1-3 psi is in order here.??
I have 1 I took off a diesel motor that a customer bought, but I have no idea where it is.. sorry
The fuel filter is before the pump
al
Thought about it more, and its probably not the pressure that is making it foam, its the volume. The lift pump feeding the injection pump doesn't need high volume, and all the diesel is mainly going back to the tank, so your filtering a lot of fuel.
Might look for a electric pump for a tractor or mower of similar size. Don't know if this would fit the bill but here is one for a BX1860 so 18hp 3cyl diesel
https://www.completetractor.com/fuel-pump-for-kubota-bx1860-bx1870-bx1870-1-bx1880-bx2360-r1401-51352/?mrkgcl=1181&mrkgadid=3279220753&adpos=1o2&creative=255456459556&device=c&matchtype=&network=g&gclid=Cj0KCQjwhuvlBRCeARIsAM720HqSXmSriRJYsam3XLkOD3sffNf_v8tQ-3uwWGDZK-oATxxCtZQ9pg4aAnRCEALw_wcB
That one looks more like mine. Thanks
   / Fuel Pump Frustration #17
NAPA has one like that. They did not have a fitting though, couldn't get on either, although it could have just been a lazy clerk
al
you can try a hardware store or plumbing supply. it's not the pressure or gpm making it foam, btw, it's air getting in the inlet of the pump. you will get some from a newly installed pump..
   / Fuel Pump Frustration #19
my ventrac 4500Z is back to dying after 30 minutes running the PTO, fist time I changed filter and found the vent line was plugged...it worked good for awhile...now its doing same thing again...this time I am going to change the electric fuel pump. Does anyone how I can cross reference this part number out on web (8J01 B76) that is what is on the pump itself, ventrac has a different # in the manual, I was hoping to find one out on web somewhere and not have to pay ventrac over 200 buck for one
   / Fuel Pump Frustration #20
If u can post a pic of the injection pump, I can tell u what pressure it runs at..
More than likely u have a PFR pump.. the ones that have an external cam shaft and sit down into it’s own little spot in the engine..??
If so, they run no more than 10 psi..
I hope this helps..
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
35in Tooth Excavator Bucket (A53421)
35in Tooth...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
JOHN DEERE 850K...
