Car Hauler vs Utility Trailer
   / Car Hauler vs Utility Trailer #1
zachofalltrades
JD GT225
I am looking at getting a new subcompact soon, and I have run into a lot of situations where I wish I had a trailer. I知 looking at a tandem about 16 long (7k) and I知 stuck on the decision of utility vs flat hauler. It seems like the car hauler is a win for a number of reasons:
1. Should I decide to pick up a project, I can open the doors when it痴 on the trailer
2. forklift can load pallets on it without railings to get in the way.
3. I can still put rails if I build them because it has stake pockets.
4. Heavy duty ramps vs fold down gate.
The utility trailer costs a couple hundred less and has a rated payload 500lbs higher because the trailer is lighter.
   / Car Hauler vs Utility Trailer #3
If going with the car trailer get ramps. I believe they'll be much stronger plus a fold down gate will be too short to load a vehicle. 16' is fine for a subcompact and most cars today but may be a little short to haul a full size truck or older larger vehicle.
   / Car Hauler vs Utility Trailer #4
I've had an 18' car hauler trailer for 18 years. Diamond plate deck. No dirt falls through the floorboards, nice and low to the ground. 2x12's make great sides with 2x4's in the pockets. Weighs 1500# with 7000# axles for 5500# useful load. My tractor weighs just 1500#. I can take it and all of my attachments in one trip. :thumbsup:
And welcome to TBN, by the way.
   / Car Hauler vs Utility Trailer #5
Only thing about a car trailer (I have one too), is that the fenders normally stick up above the deck surface, so since you mentioned loading and unloading with a fork lift, the fenders do tend to get in the way when you come in from the sides.
I'm planning on adding a gooseneck deckover trailer to my collection for just this reason.
   / Car Hauler vs Utility Trailer #6
I upgraded to a deckover to get rid of fenders. A little harder to load a tractor or vehicle on due to the angle. WAY easier to load stuff over the sides with forks. My old gravity tilt had a 4" lip on the sides & front that drove me nuts.
   / Car Hauler vs Utility Trailer #7
I own a car trailer and a large single axle landscape trailer. They each have there own uses. Fenders do get in the way but the rails are always in the way if your loading pallets. My landscape trailer has a removable rail, it didnt come that way and took alot of fab work on my part.
I prety much dont ever use one trailer and think to my self i wish i used the other. They each have there uses. If your getting a car trailer get a solid deck, wish mine had it.
If your mostly useing it for your tractor get the car trailer. Its more suited for that. Landscape trailers are more for mowers, quads and yard waste.
Thanks for all of the replies, and the warm welcome. A deckover is probably out of the question because theyæ±*e usually overkill for pulling with a half-ton and the cheapest new one I found was about 5 grand. If I buy that I wouldn稚 be able to afford the tractor lol
It sounds like I値l lean towards the car hauler. I壇 add a link but I need two more posts. The one I知 looking at is $1995 for an 18 ft dovetail. Add $200 for a steel deck. Theyæ±*e unbranded but you can order custom trailers from them, so I知 not sure if they make them in house. The place is called Oquinn Trailer in Coeburn VA.
   / Car Hauler vs Utility Trailer #9
Just to add to your shopping list, these are fantastic trailers, pending your budget. I have the 18' open car hauler.. a great "do-all" trailer for light duty tasks.
RNR Trailers
   / Car Hauler vs Utility Trailer #10
The brand really dosnt matter. At the end of the day its all about the specs.
Post the specs for the trailer and what tractor you have.
   / Car Hauler vs Utility Trailer #11
I have a 16' dual axle 7000# car hauler. My 4,000 lb tractor with loader fits nicely. If I would put a brush hog on the back it would hang over about 2 feet at the back of the trailer. The last 2 ft of the trailer is a dovetail and the loading ramps slide underneath under the dovetail section. The trailer has electric brakes. I installed a brake controller in the truck where I can adjust the pressure as needed. Yes the fenders get in the way sometimes....but still can put a whole pallet of (72) 50# bags of concrete on the trailer with no problem of the fenders being in the way.
   / Car Hauler vs Utility Trailer #12
I have a 18ft and ford 851 with loader. With a box blade on the back im about 8in from hanging off the back. I couldnt fit my tractor with a brush hog but dont mow with it.
One key to getting the proper toung weight is deck space. To small of a trailer makes this really tough. 16ft is a prety short car trailer and wouldnt be good for even a half ton extended cab truck wirh 8ft bed.
   / Car Hauler vs Utility Trailer #13
Some time ago, I organized a group but of 230 HD plasma cutters from China. (Two hundred and thirty) Drove to Seattle to pick up 11 pallet loads with the flat bed trailer with fenders that gets in the way. I had them load each pallet on the front and used their pallet jack to distribute them on the trailer without any issues.
If you do it often, a pallet jack and a few pallets wouldn’t be a bad investment in order to haul much heavier materials since you want it just in front of the axles to satisfy the 60/40 ratio.
   / Car Hauler vs Utility Trailer #14
I have had both. Not a ton of difference. Rails on utility come in handy sometimes and are handy for tie downs. They also get in the way from time to time.
   / Car Hauler vs Utility Trailer #15
Some time ago, I organized a group of 230 HD plasma cutters from China. (Two hundred and thirty) Drove to Seattle to pick up 11 pallet loads with the flat bed trailer with fenders that gets in the way.
How you got 230 welders to stay on 11 pallets is beyond me but getting work permits must have been a real challenge considering current political climate. :)
I have a 17" aluminum car hauler that works great for me, it has torsion axles you don't often find on utility or equipment trailers. Also, it sits very low and once everything is properly secured I hardly notice I'm pulling a trailer.
Good Luck!
   / Car Hauler vs Utility Trailer #16
Floor strength is a usual difference between utility trailers and car haulers, box trailers, etcetera. Last week we had a demolition boom hauled back from the Bauma exhibition in Munich, in a curtainsider trailer. It went through the floor, and the Polish charter said a lot of "kurwa" 🤣🤣
   / Car Hauler vs Utility Trailer #17
As long as you are talking a compact tractor a car hauler trailer will work well. I have an 18' car hauler with two 7,000 axles that my Kubota fits on just fine. My John Deere is another story - the rear tires will not fit between the fenders of the car hauler even though they are set at their narrowest position.
   / Car Hauler vs Utility Trailer #18
I wrestled with the same dilemma a few years ago. I figured the rails would be enormously handy to have much of the time, and a hindrance once in a long while. I came real close to pulling the trigger on several trailers, both car haulers and landscape utilities, before I found the one I bought. When I look back, I feel like I dodged a bullet because the one I ended up buying has much, much nicer features than any of the others I looked at.
I ended up with a PJ 16' dual axle 7000# landscape utility and could not be happier with it. It eliminated my concerns about loading from the side with the rails, because the rails can be removed when I need and bolted back in when I want them. That said, guess how many times I've found myself in a situation where it was going to be worth bothering to do that so far? Zero. On the other hand, the rails have been a huge benefit when using the trailer to haul other things such as furniture, hay bales, etc.. It adds a margin of safety in terms of keeping loads of that sort contained on the trailer, and provides great tie-down points. And, the PJ landscape utility still has separate stake pockets as well, which I use for chaining tractors and I also made some short plywood walls that are very quickly and easily removable for hauling firewood that use the stake pockets for the install.
The PJ comes with a Bulldog coupler which I really like. Came with a jack I can swivel up and out of the way. The fenders are aluminum so they won't rust, and they're removable so down the road if I need to do some work on the trailer, I'm not stuck working around the fenders because they're welded on. I love the gate in the back, makes loading great and again provides another measure for keeping certain types of loads contained on the trailer. Cold weather wiring harness stays soft and flexible in cold weather, although I don't use my trailer in the winter (so far); I put it away in a garage up on blocks for the winter. Lights are integrated into the frame, not hanging out where they can be easily torn off, and the same with wiring.
Just all in all, I think it's a much smarter put-together trailer than any of the other options I looked at.
Some pics:
Here's a trip that was made much easier being a landscape utility rather than a car hauler:
Walls I made for hauling firewood. They're hinged in the middle, unfold, and I have short sections of 2x4 bolted to them that drop into the stake pockets. Since the rails are there, they really provide all the strength. The plywood is just needed to keep logs from falling out.
Here they are folded up.
Some red oak. Doesn't look like much, but there's more weight than it may seem.
Thanks everybody for the great responses! The utility trailer argument does sound good for the sake of hauling bulk materials that aren't on pallets, like mulch/gravel/dirt. PA452, that's a sweet looking trailer, but they don't have a dealership close to me and those are a bit pricey from what I saw. Not saying they're not worth it, but just more than I'm looking to put down on a trailer I won't use daily. To answer some of the other questions: I don't own the tractor yet, still shopping. But I won't get anything bigger than a standard compact (something in the 25hp range).
Now that I've had enough posts, I can post links :)
Here is the utility trailer in question: 219 Other (Not Listed) 76X16 gate brake Utility Trailer | O Quinn Trailers in Coeburn VA | New and used enclosed cargo mate and flatbed gatormade trailers including Gatormade
And the car hauler: 219 Other 82x18 wood car hauler Car / Racing Trailer | O Quinn Trailers in Coeburn VA | New and used enclosed cargo mate and flatbed gatormade trailers including Gatormade
   / Car Hauler vs Utility Trailer #20
The utility trailer looks like an angle iron frame. It's 500lbs lighter. Maybe fewer and smaller crosspieces, too.
I'd buy the car hauler and make removable sides.
Add brakes to the second axle, too.
Bruce
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2019 BOBCAT T450 SKID STEER (A60429)
2019 BOBCAT T450...
2022 John Deere R4023 (A60462)
2022 John Deere...
2017 Case CX145D (A60462)
2017 Case CX145D...
