Car Hauler vs Utility Trailer
   / Car Hauler vs Utility Trailer #11
I have a 16' dual axle 7000# car hauler. My 4,000 lb tractor with loader fits nicely. If I would put a brush hog on the back it would hang over about 2 feet at the back of the trailer. The last 2 ft of the trailer is a dovetail and the loading ramps slide underneath under the dovetail section. The trailer has electric brakes. I installed a brake controller in the truck where I can adjust the pressure as needed. Yes the fenders get in the way sometimes....but still can put a whole pallet of (72) 50# bags of concrete on the trailer with no problem of the fenders being in the way.
   / Car Hauler vs Utility Trailer #12
I have a 18ft and ford 851 with loader. With a box blade on the back im about 8in from hanging off the back. I couldnt fit my tractor with a brush hog but dont mow with it.
One key to getting the proper toung weight is deck space. To small of a trailer makes this really tough. 16ft is a prety short car trailer and wouldnt be good for even a half ton extended cab truck wirh 8ft bed.
   / Car Hauler vs Utility Trailer #13
Some time ago, I organized a group but of 230 HD plasma cutters from China. (Two hundred and thirty) Drove to Seattle to pick up 11 pallet loads with the flat bed trailer with fenders that gets in the way. I had them load each pallet on the front and used their pallet jack to distribute them on the trailer without any issues.
If you do it often, a pallet jack and a few pallets wouldn’t be a bad investment in order to haul much heavier materials since you want it just in front of the axles to satisfy the 60/40 ratio.
   / Car Hauler vs Utility Trailer #14
I have had both. Not a ton of difference. Rails on utility come in handy sometimes and are handy for tie downs. They also get in the way from time to time.
   / Car Hauler vs Utility Trailer #15
Some time ago, I organized a group of 230 HD plasma cutters from China. (Two hundred and thirty) Drove to Seattle to pick up 11 pallet loads with the flat bed trailer with fenders that gets in the way.
How you got 230 welders to stay on 11 pallets is beyond me but getting work permits must have been a real challenge considering current political climate. :)
I have a 17" aluminum car hauler that works great for me, it has torsion axles you don't often find on utility or equipment trailers. Also, it sits very low and once everything is properly secured I hardly notice I'm pulling a trailer.
Good Luck!
   / Car Hauler vs Utility Trailer #16
Floor strength is a usual difference between utility trailers and car haulers, box trailers, etcetera. Last week we had a demolition boom hauled back from the Bauma exhibition in Munich, in a curtainsider trailer. It went through the floor, and the Polish charter said a lot of "kurwa" 🤣🤣
   / Car Hauler vs Utility Trailer #17
As long as you are talking a compact tractor a car hauler trailer will work well. I have an 18' car hauler with two 7,000 axles that my Kubota fits on just fine. My John Deere is another story - the rear tires will not fit between the fenders of the car hauler even though they are set at their narrowest position.
   / Car Hauler vs Utility Trailer #18
I wrestled with the same dilemma a few years ago. I figured the rails would be enormously handy to have much of the time, and a hindrance once in a long while. I came real close to pulling the trigger on several trailers, both car haulers and landscape utilities, before I found the one I bought. When I look back, I feel like I dodged a bullet because the one I ended up buying has much, much nicer features than any of the others I looked at.
I ended up with a PJ 16' dual axle 7000# landscape utility and could not be happier with it. It eliminated my concerns about loading from the side with the rails, because the rails can be removed when I need and bolted back in when I want them. That said, guess how many times I've found myself in a situation where it was going to be worth bothering to do that so far? Zero. On the other hand, the rails have been a huge benefit when using the trailer to haul other things such as furniture, hay bales, etc.. It adds a margin of safety in terms of keeping loads of that sort contained on the trailer, and provides great tie-down points. And, the PJ landscape utility still has separate stake pockets as well, which I use for chaining tractors and I also made some short plywood walls that are very quickly and easily removable for hauling firewood that use the stake pockets for the install.
The PJ comes with a Bulldog coupler which I really like. Came with a jack I can swivel up and out of the way. The fenders are aluminum so they won't rust, and they're removable so down the road if I need to do some work on the trailer, I'm not stuck working around the fenders because they're welded on. I love the gate in the back, makes loading great and again provides another measure for keeping certain types of loads contained on the trailer. Cold weather wiring harness stays soft and flexible in cold weather, although I don't use my trailer in the winter (so far); I put it away in a garage up on blocks for the winter. Lights are integrated into the frame, not hanging out where they can be easily torn off, and the same with wiring.
Just all in all, I think it's a much smarter put-together trailer than any of the other options I looked at.
Some pics:
Here's a trip that was made much easier being a landscape utility rather than a car hauler:
Walls I made for hauling firewood. They're hinged in the middle, unfold, and I have short sections of 2x4 bolted to them that drop into the stake pockets. Since the rails are there, they really provide all the strength. The plywood is just needed to keep logs from falling out.
Here they are folded up.
Some red oak. Doesn't look like much, but there's more weight than it may seem.
Thanks everybody for the great responses! The utility trailer argument does sound good for the sake of hauling bulk materials that aren't on pallets, like mulch/gravel/dirt. PA452, that's a sweet looking trailer, but they don't have a dealership close to me and those are a bit pricey from what I saw. Not saying they're not worth it, but just more than I'm looking to put down on a trailer I won't use daily. To answer some of the other questions: I don't own the tractor yet, still shopping. But I won't get anything bigger than a standard compact (something in the 25hp range).
Now that I've had enough posts, I can post links :)
Here is the utility trailer in question: 219 Other (Not Listed) 76X16 gate brake Utility Trailer | O Quinn Trailers in Coeburn VA | New and used enclosed cargo mate and flatbed gatormade trailers including Gatormade
And the car hauler: 219 Other 82x18 wood car hauler Car / Racing Trailer | O Quinn Trailers in Coeburn VA | New and used enclosed cargo mate and flatbed gatormade trailers including Gatormade
   / Car Hauler vs Utility Trailer #20
The utility trailer looks like an angle iron frame. It's 500lbs lighter. Maybe fewer and smaller crosspieces, too.
I'd buy the car hauler and make removable sides.
Add brakes to the second axle, too.
Bruce
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
43030 (A51691)
43030 (A51691)
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
