Shop Walls
   / Shop Walls #11
Old privacy fence pickets. People are always selling it around my area when they put up new fence. A lot of the time the pickets are still good. Maybe a little warped, but if you put them up against studs I think they should straighten out. Would look rustic and "nice" in some people's opinion.
   / Shop Walls #12
I just put up plywood. Intended to paint it all white, but you know how that goes. The white showing above the plywood is insulation.
   / Shop Walls #13
What is the story with your lattice trusses? were they part of a kit or did you make them? I am about to wrap up my DIY pole barn and my first plan was to make trusses like that. I bought the metal to make 5 of them, but after spending a whole day making just one, I decided it wasn't worth the effort so I wrote that idea off. Instead I ended up using back-to-back C-Purlin as trusses. Wasted $400 worth of materials and a day of labor but I still would have preferred lattice trusses. if they sell those somewhere I'd like to know.
   / Shop Walls #14
My buddy used OSB in his shop & it looks cheap.. JMO
1 thing he did tell me when I was doing mine>> KEEP the wood OFF THE FLOOR..
All around the floor in HIS, it looks like the dog came in & marked his territory.. Lol
That OSB will wick-up any moisture on the floor..
I used a 10' 1x4 on the floor as a spacer when I put up my 1/2" BC plywood walls.{sanded on 1 side}
IT worked out great.. & I do get some water intrusion in certain spots when it rains.. but NO wicking.!!!
   / Shop Walls #15
The building is about 15 years old; it was a package deal, built on sight by Callahan buildings.
Callahan Steel | 48 Years of Building Excellence!
They did it all except the plywood walls and the electricity.
   / Shop Walls #16
I have painted OSB on part of my garage walls. 3 courses of cement block then 4' of OSB and 4' of drywall for the ten foot sides. The garage foot print is 28'x40'x10' which used over 40 gallons of primer and white paint on walls and ceiling.
   / Shop Walls #17
My shop with 12’4” walls has OSB vertically on the upper parts and floating horizontally at bottom, spaced evenly between the top & bottom. 2 x 6 for “chair rail” and “baseboard”. The chair rail 2 x 6 protects the air line & electrical lines mounted above it. Baseboards protects the wall from mechanical man-made ground critters plus it hides imperfections.
   / Shop Walls #18
40 Gallons! Woa! I’m thinking about doing the same thing in my 40x50. Was going to try using an airless but did not expect to need that much. Wow. I guess I have my work cut out for me.
   / Shop Walls #19
Puck board that lines the boards on hockey rinks is very tough, albeit somewhat costly, looks great. Comes in different thicknesses, check your local home depot, etc.
   / Shop Walls #20
That’s a really cool idea. But extremely expensive.
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53472)
NEW 2024 LOAD...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
