Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
That's a lot more realistic looking graph than tour first test. No doubt alot more accurate too
Yeah, I just wish I was able to edit post #1 to add a line at the very top that says see post #47 for correct data.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #52
I see the results of the hyd fluid getting warmer during the test.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #54
Meaning the converging sets of data?
Yes. Lift Vs rpm convergence shows the effect of viscosity decrease. But not surely. - Maybe heating was very minor over the test. - A convergence proportional to lift is also to be expected and that may be ALL it is.
Thanks for pointing that out. I hadn't noticed that before. :)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #56
Welcome. Note I must have edited as you answered. There are two contributing explanations. For all I know you could have worked the tractor beforehand. In which case, cooling oil would have had some offsetting effect on convergence that was strictly proportionate to the lift figure. . . . Or in the case of warming the convergence effect would have been accentuated.
It was definitely due to warming of the fluid. The tractor had been idling for a while before the test, but the fluid definitely got warmer throughout the test. Especially spending all that time flowing through the relief valve while the scale settled out each time.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #58
How is post #1 now?
Aaron Z
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
