Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
That's a lot more realistic looking graph than tour first test. No doubt alot more accurate too
Yeah, I just wish I was able to edit post #1 to add a line at the very top that says see post #47 for correct data.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #52
I see the results of the hyd fluid getting warmer during the test.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #54
Meaning the converging sets of data?
Yes. Lift Vs rpm convergence shows the effect of viscosity decrease. But not surely. - Maybe heating was very minor over the test. - A convergence proportional to lift is also to be expected and that may be ALL it is.
Thanks for pointing that out. I hadn't noticed that before. :)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #56
Welcome. Note I must have edited as you answered. There are two contributing explanations. For all I know you could have worked the tractor beforehand. In which case, cooling oil would have had some offsetting effect on convergence that was strictly proportionate to the lift figure. . . . Or in the case of warming the convergence effect would have been accentuated.
It was definitely due to warming of the fluid. The tractor had been idling for a while before the test, but the fluid definitely got warmer throughout the test. Especially spending all that time flowing through the relief valve while the scale settled out each time.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #58
How is post #1 now?
Aaron Z
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
