Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
That's a lot more realistic looking graph than tour first test. No doubt alot more accurate too
Yeah, I just wish I was able to edit post #1 to add a line at the very top that says see post #47 for correct data.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #52
I see the results of the hyd fluid getting warmer during the test.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #54
Meaning the converging sets of data?
Yes. Lift Vs rpm convergence shows the effect of viscosity decrease. But not surely. - Maybe heating was very minor over the test. - A convergence proportional to lift is also to be expected and that may be ALL it is.
Thanks for pointing that out. I hadn't noticed that before. :)
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #56
Welcome. Note I must have edited as you answered. There are two contributing explanations. For all I know you could have worked the tractor beforehand. In which case, cooling oil would have had some offsetting effect on convergence that was strictly proportionate to the lift figure. . . . Or in the case of warming the convergence effect would have been accentuated.
It was definitely due to warming of the fluid. The tractor had been idling for a while before the test, but the fluid definitely got warmer throughout the test. Especially spending all that time flowing through the relief valve while the scale settled out each time.
   / Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #58
How is post #1 now?
Aaron Z
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
12in Backhoe Bucket (A53472)
12in Backhoe...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
40' CONTAINER (A51248)
