Why no heavy duty Chevy pickup?
   / Why no heavy duty Chevy pickup? #81
That's what I read also crashz. They are dropping their sheet metal on an international chassis & drive train. CV Series | Class 4/5 Truck | International Trucks
I just went to IH on the web and it looks like they are as you said partnered up, using GM's sheet metal but an IH grill.
Do you know if they are using the IH 6.6 or sticking with the D max?
. It痴. Chevy 6.6 not an IU engine . Chev stroked the 6.2 out to 6.6. Lowered the compression some and used a cast iron block . The engine was designed and decided on back when it looked like H I l l A R Y would win the election and the EPA would place Tier V and Tier VI emissions on the diesels
I don’t think a 6.2 shares anything with 6.6. The 6.5 was the 6.2s cousin.
   / Why no heavy duty Chevy pickup? #83
I'm thinking B&D was talking about the new 6.6 GAS engine that is replacing the 6.0 gas engine.
   / Why no heavy duty Chevy pickup? #85
Yeah, unlike the 6.2 Ecotec in the 1/2 tons, the 6.6 coming out is a working motor. It does have DI, but not the goofy AFM cylinder shutdown nonsense that the 1/2 ton pickups have. And has been stated, a lower compression so premium fuel is not required for optimal performance. There is not enough there to cause me to get rid of the Chevy 2015 2500 6.0 I have now. Besides, I would never by a new production engine. Let everyone else be a guinea pig until all the bugs are worked out.
One aspect to the new GM medium duty trucks coming out that I do think is long overdue in HD pickups.... clamshell hoods like semi trucks making access to engine far easier for maintenance. There are several other features that are pretty well thought out. If I was in the market for a medium duty, I would consider one of the new GM 4500/5500 series. Lots of build options available.
1R PLOW, 3PT (A52708)
2006 Mercedes-Benz Unimog LWBTruck (A56858)
2006 Mercedes-Benz...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
IRET13 ELECTRIC TRICYCLE (A58216)
IRET13 ELECTRIC...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2012 UTILITY TRAILER MANUFACTURER FLATBED (CRACKED FRAME) (A58214)
2012 UTILITY...
