My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower
8 hrs on my recently purchased ZD1211, wish I’d done three things different:
(1) Concerned about being under powered I chose the 60” over 72”.
Trimming in pasture, out of curiosity, I purposely ventured into some tall thick stuff - went through it like a champ. Motor barely changed its tune, but the deck didn’t discharge the grass as quick as I’d liked, so possible choking situation. (Keep in mind this is thick tall stuff normally cut with tractor & rotary cutter.)
(2) Definitely wish I had chosen a rear discharge. Will have to modify grass deflector before it gets ripped off.
(3) Why didn’t I buy a ZTR years ago? Often stated that we need a Cat dozer with a belly mower attachment around our property. Got the ZD1211 in a couple of muddy spots that our GR 2120 wouldn't have even spun a wheel, but it’s a lop sided trade when you compare cutting times.
All in all, VERY happy ZD owner!
"Will have to modify grass deflector before it gets ripped off."
My previous ZT was a John Deere Z820A with side discharge 60" deck.
I drilled a 1/4" hole, near the outer edge of the hinged deflector, so I could hold it up vertical with a short bungee cord. It stayed up a majority of the time as it threw the clipping our further.
Our new ZD1211 is rear discharge 72" deck.
   / My New Kubota ZD1211 Mower #122
Are those factory fender extensions below fuel tanks?
   / My New Kubota ZD1211 Mower #124
Mine didn’t come with the fender extensions.
   / My New Kubota ZD1211 Mower #126
I bought mine in June 18. Right off truck and put together. Strange Ill see if mine has mounting spot for them
Even if you look online at pictures of new ones for sale at dealers not one 2019 has them. Are you in Canada or something lol?
"Are you in Canada or something lol?"
Even better ..... Texas!
   / My New Kubota ZD1211 Mower #128
My mower has nuts welded under tank to bolt fenders on. Now I want them. With all the rain this spring it’s been a muddy mess
If you get a chance do me a favor. See if there’s any visible part number on those. Thanks!
   / My New Kubota ZD1211 Mower #130
No abusive usage here, just myself on a normal lawn.
Grass got stuck in the right front deck wheel preventing it from turning.
Didn't take long to put a flat spot on it.
Rear deck wheels are held by single flange, already bent.
Needs two flanges or thicker steel.
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
UNUSED FUTURE LS43 43" HYD LOG SPLITTER (A58376)
UNUSED FUTURE LS43...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
Parts to Harrow Disc (A57149)
Parts to Harrow...
2011 INGERSOLL RAND  G25 GENERATOR (A58216)
2011 INGERSOLL...
2011 Case-IH 155 Puma (A57148)
2011 Case-IH 155...
