My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower
8 hrs on my recently purchased ZD1211, wish I’d done three things different:
(1) Concerned about being under powered I chose the 60” over 72”.
Trimming in pasture, out of curiosity, I purposely ventured into some tall thick stuff - went through it like a champ. Motor barely changed its tune, but the deck didn’t discharge the grass as quick as I’d liked, so possible choking situation. (Keep in mind this is thick tall stuff normally cut with tractor & rotary cutter.)
(2) Definitely wish I had chosen a rear discharge. Will have to modify grass deflector before it gets ripped off.
(3) Why didn’t I buy a ZTR years ago? Often stated that we need a Cat dozer with a belly mower attachment around our property. Got the ZD1211 in a couple of muddy spots that our GR 2120 wouldn't have even spun a wheel, but it’s a lop sided trade when you compare cutting times.
All in all, VERY happy ZD owner!
"Will have to modify grass deflector before it gets ripped off."
My previous ZT was a John Deere Z820A with side discharge 60" deck.
I drilled a 1/4" hole, near the outer edge of the hinged deflector, so I could hold it up vertical with a short bungee cord. It stayed up a majority of the time as it threw the clipping our further.
Our new ZD1211 is rear discharge 72" deck.
   / My New Kubota ZD1211 Mower #122
Are those factory fender extensions below fuel tanks?
   / My New Kubota ZD1211 Mower #124
Mine didn’t come with the fender extensions.
   / My New Kubota ZD1211 Mower #126
I bought mine in June 18. Right off truck and put together. Strange Ill see if mine has mounting spot for them
Even if you look online at pictures of new ones for sale at dealers not one 2019 has them. Are you in Canada or something lol?
"Are you in Canada or something lol?"
Even better ..... Texas!
   / My New Kubota ZD1211 Mower #128
My mower has nuts welded under tank to bolt fenders on. Now I want them. With all the rain this spring it’s been a muddy mess
If you get a chance do me a favor. See if there’s any visible part number on those. Thanks!
   / My New Kubota ZD1211 Mower #130
No abusive usage here, just myself on a normal lawn.
Grass got stuck in the right front deck wheel preventing it from turning.
Didn't take long to put a flat spot on it.
Rear deck wheels are held by single flange, already bent.
Needs two flanges or thicker steel.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
17201 (A55852)
17201 (A55852)
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
