My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower #131
Maybe the deck was riding little too close to the ground in the rear?
My mower has nuts welded under tank to bolt fenders on. Now I want them. With all the rain this spring it’s been a muddy mess
If you get a chance do me a favor. See if there’s any visible part number on those. Thanks!
I don’t see any numbers on mine. I’ll stop by my Kubota Dealer and see what they know.
   / My New Kubota ZD1211 Mower #133
My bracket plates are bent too for the rear deck wheels BUT it’s my fault hanging them on trees.
I’d like to take the brackets off under the Rear Discharge Deck to help On Windrows But it would let Blades scalp the ground on hi ridges.
   / My New Kubota ZD1211 Mower #134
Four hours on the new ZD 1211 and could not be happier. A real upgrade over my ZD1800 that is now on the dealers showroom. Two areas in my yard I have to watch and the 60" deck is just enough larger to cause scalping whereas the 54" deck on the ZD1800 would not. No big thing and I like the increased power, ease of raising and lowering the deck ( need learn to keep my foot off the peddles) and the new seat is fantastic compared to the one on the traded ZD 1800 twelve years makes a difference. Some of the mowing was in thick grass well over foot tall and the 1211 never even slowed down. Good buying decision
   / My New Kubota ZD1211 Mower #135
... the 60" deck is just enough larger to cause scalping whereas the 54" deck ... would not ...
You must be mowing with the deck awfully low ?
   / My New Kubota ZD1211 Mower #136
anyone use a Oregon # 91-144 with a modified hole, or 92-049 with correct hole.
I'm looking for something that will result in stripes ?
   / My New Kubota ZD1211 Mower #137
I mow at 1 1/2 in in the spring too entice the Bermuda to spread. As the temps get up ( June on) I mow at 2 inches. Earlier this week was my last 1 1/2 " mow for the season as we are going to have our first 100 degree day this weekend
   / My New Kubota ZD1211 Mower #138
Wow. That’s awful short. I’m at 2.75”
3-3.5” here.
   / My New Kubota ZD1211 Mower #140
I wish I had bought a 72'' 1211 instead of the 60'' 1021
Don't get me wrong. the little 1021 is a beast ! I just need 72 inch cut.
86"X18' DOUBLE AXLE TRAILER (A58375)
86"X18' DOUBLE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500 BBL FRAC TANK (A58216)
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
500BBL WHEELED...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
