TODAYS SEAT TIME
   / TODAYS SEAT TIME #9,701
My "seat time" has been doing more custom rotavating...
I tilled a field for a lady and half of it was quite wet, that means it tills VERY HARD, putting max stress on the tiller and tractors drive line. I had to adjust the drive line clutch a couple times to keep it from slipping, and as the clutch was about used up from years of hard work there wasn't much adjustment left in it.
SO, when I got home, I took it apart and one friction disc was completely missing, so it must of broke up and fell out, no matter I just threw in a new one and as the second disc was still in pretty good shape, I didn't replace it,
Next time I go out, I'll give it it's final adjustment and that should take care of the problem!
SR
   / TODAYS SEAT TIME #9,702
I spent 5 hours watching a mini chip rock while occasionally using my backhoe to clear chips. Then we set the tank. I値l have to dig fill lines in a few days. I still haven稚 completed the State course to be a licensed septic system installer. Mini excavators might dig better then backhoes but not when theyæ±*e half the size. That mini would have no chance beating my backhoe at much of anything.
Looks like some hard ground there for a septic system. Is there more to the system like a leach field or mound system or is it just a tank that gets pumped every time it gets filled with water and stuff ??
gg
   / TODAYS SEAT TIME #9,703
gg
I agree with the "hard ground" comment Gordon . . . of course a leach field has to come next . . .
   / TODAYS SEAT TIME #9,704
You would think but I was curious because he only mentioned digging the sewer pipe lines. Maybe the lack licence is the problem - should have thought of that. But we have places here where leach systems aren't allowed, like near water or on a ledge, and it is just a tank that gets pumped when full of water.
gg
   / TODAYS SEAT TIME #9,705
gg
Yes anywhere you have a creek, river any runoff that ends up in the waterways.
   / TODAYS SEAT TIME #9,706
That one is a short range pistol range I've just set up.(the bench is not the correct tool for the job, but makes a good table for now.
What do you think of my little plates?? :laughing:
I have another range for 100 yard shooting down in the woods, and a range (1 target and a pair of gongs) out of my back yard at 250 yards.
Pistil range,,,,,, forgot about that option, always need a table for pistil shooting. I moved all my photos from PB to Imgur 2 months ago, their site works better.
   / TODAYS SEAT TIME #9,707
It’s getting a leech field but there’s not a huge hurry to finish this project. The rock is between 30 and 48 inches and the leech field only has to be 22” so it shouldn’t cause any problems.
   / TODAYS SEAT TIME #9,708
For the first time in several years I put on the old IH 111 5 foot rotary mower which my father gave me when I bought my first tractor. For some reason I thought there was something wrong with it so have been trying to find time for repairs; but after checking it out I remembered that it was a bit too heavy for the old L275, which was also getting tired.
I had forgotten how much fun it is to run and what a nice job it does... even with the extremely dull blades. I still would be out there mowing by the headlights if I had an open field. Some people plow around the stumps, I mow around the fruit trees which I've been planting over the past few years. I'll be back at it first thing tomorrow AM. :thumbsup:
   / TODAYS SEAT TIME #9,709
14.9/24's for fronts and 16.9/34 for tears. Only had it about 2 weeks now
TractorData.com Farmtrac 795DTC tractor information
that's a very nice looking tractor. Deutz Fahr is highly regarded. Same weight as my 4707 Massey which came with optional larger 34's on rear,
which it looks like yours does also, originally spec'd with 30s on the rear. Those large radials have serious grip, imagine you will be the puller and not the pullee
in mud situations.
I've had a few places where I had to go forward with the bucket almost all the way up, like carrying a large amount of debris and trying to go through a fence gate.
But the higher that bucket goes, with weight in it, the more nervous I get. Putting on seat belts might be a good habit to get into.
With bigger fronts, less likely to drop into a small depression, I really like the big tires. Plus the ride is improved.
I always run with a big finish mower on the back and have filled rear tires, so not worried about getting tippy.
Just always remember you're just a big teeter totter out there, always have more in the rear...
I also own a high quality man lift that I lift someone pretty far up several times a year to trim my treelines, nowhere near electric.
So that is surely driving forward with the bucket raised all the way. Just have to go very, very slowly and watch carefully where driving.
My land is mostly pool table flat, but there are always holes in ground and for sure lots of ditches. Drop a wheel in a ditch when you don't want to
and life gets very exciting in a hurry. With a raised bucket, surely won't end well.
   / TODAYS SEAT TIME #9,710
Got our hay in, over the past few days. About 500 bales went in the barn.
Dad's ol Massy 135 chugged right along, only a handful of mis-ties from the MF12 baler. Nice to work on mostly flat ground for a change!
2022 TAKEUCHI TL8R2 SKID STEER (A60429)
2022 TAKEUCHI...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 CATERPILLAR D3 CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2019 Dorsey DF40 40ft. 40 Ton T/A Drop Deck Flatbed Trailer (A60460)
2019 Dorsey DF40...
