Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build
   / Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build
I壇 go with the MX5200 because of the turbo ;). Get 3 rear remotes one with float detent. Get the 3rd function on the loader. Top N tilt cylinders for the 3pt. Get a nice heavy duty Gearmore box blade, with hydraulic rippers. A hydraulic auger would be nice to have for your fencing chores.
I do like turbos :)
It's my hope that I have time (before I kick it) to turbocharge this baby:
What is the 3rd function on the loader? Is that the feature that automatically keeps it level?
Gustave
That tractor won稚 pop walnut stumps and I wouldn稚 bother grading with it unless you?*e experienced with a box blade with a hydraulic top link and that would only be finish grading... very light stuff. My 2 cents as owning an excavating business
Understood. Thanks. Major grading will be done by a mix of professionals and amateurs (us) with rented equipment.
   / Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #63
The third function on a Loader is used in conjunction with a grapple. That hydraulic port opens and closes the grapple maw.
You maintain the Loader level or at whatever angle is desired with the joystick. Third function control is often a button or rocker switch added to the joystick.
Levers for rear remotes, one lever for each pair of rear remotes, usually occupy empty factory provided slots on the tractor control console.
   / Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #64
I would go with the MX - you can widen the wheels for stability and it is the larger class tractor. I owned an L and now and MX and do a lot of similar chores and love the MX.
As for stumps - rent a mini ex for the weekend and knock it out - lot easier and faster. Trying to pull them with a tractor is tough and a lot of work. Dig them out with the mini then use the tractor to move them to where you want to dump or bury them.
What he said!
   / Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #65
I do like turbos :)
Gustave
Awesome truck!!! That will be a GREAT project!
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
