Welding to FEL Bucket --- Gas or Arc?
   / Welding to FEL Bucket --- Gas or Arc? #21
If you are talking oxy-acetylene welding when speaking of gas welding, then I wouldn't do that. Too much heat input to the FEL bucket which could cause warping. Go with electric arc (smaw) welding for the best weld. A high voltage MIG or FCAW would work but I wouldn't consider some of the 120V cheapy units or even some of the 220V low power units.
SMAW will be the cheapest and fastest and provide the best quality welds. MIG and FCAW are notorious for non-fusion in the welds especially if the welder is not really experienced or if the machine is not capable of high amperage.
Most gas welders I have experienced always use too large a tip hence the warping. As a piping foreman we did a lot of gas welding on 2" and smaller pipe. I always provided only one tip of the proper size and they always complained. When I demonstrated the proper size tip the whining stopped. The plan was use the right tip or go back to the union hall and practice in the training shop. We seldom had warping problems with pipe. Do not ask me sizes as that was a long time ago.
I agree with you Gary on the MIG and penetration. Fabrication on assembly lines with MIG are notorious for not getting penetration, its is a fine looking bead but is laid just on top as they do not bevel or gap. I have had to re-weld several places on implements. Took a new one back for warranty. They tried to argue about it till I pointed out that one side did not even have a burn mark.
My welds today look crappy but the penetration is there. Age has caught up with the steady hand.
Disconnecting the electric gear is an urban legend. As long as the current does not flow through a connection to the battery, no problem. Always connect the ground cable as close to the weld as possible with good metal to metal contact.
Ron
   / Welding to FEL Bucket --- Gas or Arc? #22
Ron
I agree with everything you said. I have to comment on the gas welding of pipe. I have only seen that done on my first construction job when I worked as a welders helper for a welder doing gas welding on some 2" pipe in 1968. Every job after that used TIG for small bore piping. The only reason for the gas welding was because of the antiquated specification of the compressor station owner (Transcontinental Gas Transmission ) that required gas welding of 2" and below piping.
By the same token, I worked on a job where I was a pipe welder in 1974 and the specs didn't allow TIG welding on small bore. I welded 1/2" buttweld hydrogen line with 6010 root. By the time you got it tacked up there was just about a 1/8 gap between tacks to fill with the root pass. It was all 100% xray so we had to be very good to pass those test. TIG would have been much easier and faster and possibly better.
   / Welding to FEL Bucket --- Gas or Arc? #23
recently installed center hook to fel bucket using arc. burned a hot 6011 root pass, grinded & cleaned, then a few 7018 passes. used a mild steel back plate.
in terms of safety to tractor electrical system, removing bucket would be the way to go.
i didn't do that, just kept the ground clamp as close to work area as possible.
have heard cases when ground clamp is attached a good distance from work, the current can pass through the crankshaft and cause damage to the main bearings. for example, if you clamp to frame, then weld (don't know why) on pulley, etc, it could happen.
can't verify & maybe a myth, but something to think about. best regards
   / Welding to FEL Bucket --- Gas or Arc? #24
Gary,
I was doing a lot of ammonia refrigeration piping back in those days. Gas welding was a production matter. 2" XH we could do in one pass, no cleaning between 2-3 passes. We could 2-3 more welds to the arc welders 1. Arc welding on small bore created more leaks also. I could do 100 gas welds and not have a leak.
One job I was called into from the hall was some 6", schd 40, vertical chilled and HW piping that had a horizontal weld every 10'. Total of almost 100 welds and every joint leaked. Old wood frame retail store 4 stories, fire department required all gas welding, and the elevator could only take the 10' sections. First crew never did get the lower point of the joint fused in, nice looking but overlapped the lower bevel. Oh, many of the welds were only 3" from the walls and some in corners. Due to the fire danger had to chip out and file the whole joint.
Put 4 fitters and apprentices working that, went to the union training shop and brushed up on my horizontal welding, ordered out some #4 short bend and standard tips. Some places I had to cut a window in the front and welded from the inside, had to fill out the bevel first on those. We were still using asbestos blankets for heat shielding. I did all the welding myself as there were no certified gas welder available from the hall.
They also had close to 100 threaded joints on 1 1/2 pipe at the coils. malleable fittings and the had the idea you had to screw the threads all the way in. hat was a lot of ruined fittings . Super asked me what would I do to keep from replacing all the fittings. Recommended trying Expando joint compound as we used a lot of that on threaded ammonia piping when Litharge was outlawed. It is a cement based paste thinned with water, sets up like a rock. Threads have to very clean with no oil. another fitter cleanup job. Supervised fixing the first set of coils. Low and behold, no leaks. Set up 3 crews and finished it all out with no more leaks and a happy boss.
Luckily I had demanded they pay me foreman pay up front and if the first riser had any leaks they could take it away. The company owner himself came out at the end and handed me a $5K bonus check. That job took a total of 6 months and now 5 months behind schedule and I was able to catch up one of those months. Stayed with that company for over a year doing mostly gas welding. They lost their shirt on that job, with an unhappy customer due to the delays and running the job into the summer.
Ron
   / Welding to FEL Bucket --- Gas or Arc? #25
"Disconnecting the electric gear is an urban legend. As long as the current does not flow through a connection to the battery, no problem. Always connect the ground cable as close to the weld as possible with good metal to metal contact."
Have always done that and never had a problem.
I ground to the part that has the most mass and to be sure I grind a small surface area to assure a good ground.
Also have welded on or near hydraulic cylinder shafts but I wrap the shafts with wet rags so no splatter can damage them.
   / Welding to FEL Bucket --- Gas or Arc? #26
above is sound advice, my experience is likewise. the wet rags also help protect nearby seals
   / Welding to FEL Bucket --- Gas or Arc? #27
When we welded ours we not only left the bucket on the tractor, we kept the tractor running so we could re-position the bucket ... we welded the center hook a little further back than the ones on the side
We used an arc welder ... I think we used 6011 rods
The other thing we did was to grind the area on the bucket so there was no paint to burn off. We also ground the back of the hooks flat to eliminate the gap that can occur between the hook and the eye from the curve of the hook.
We did not get any warping or weakening of the bucket or the hooks.
   / Welding to FEL Bucket --- Gas or Arc? #28
I had to check the shop to see if my welder was still there. LOL
   / Welding to FEL Bucket --- Gas or Arc? #29
ive got some pictures of that cable mgmt in some other pictures i just havent gotten around to fabricating that part yet HA!!! nice welder i debated whether to go with black on my dial or not couldnt decided what i liked better
   / Welding to FEL Bucket --- Gas or Arc? #30
I went black on the dial because I was too lazy to polish out the scratches.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
