Gannon/Woods HD4272 hydraulic box blade
   / Gannon/Woods HD4272 hydraulic box blade #1
biggziff
Upstate NY
2015 Kioti CK4010HST
I have a buddy with a HD4272 hydraulic box blade he wants to sell me. It's in like new condition. I'm assuming these are the king daddy of box blades. Anything to look out for?
1140 pounds, cat 1/2, 40-80 hp tractors according to Woods.
Thanks
   / Gannon/Woods HD4272 hydraulic box blade #2
Yes, in my opinion at least. I have a Land Pride HR3584 and it's very similar. We have a Woods rotary cutter and it has held up well.
May I ask what tractor you pull it with?
   / Gannon/Woods HD4272 hydraulic box blade #4
You're right about the quality, but you may find out what "tail wagging the dog" means - I have an original Gannon (actually MADE by gannon) 80", run it on the back of my (NOT compact) Allis 160 - the Allis weighs literally a TON more than your Kioti (if that's what your intention is) - I have just under 600 pounds of front weights on the Allis, and there are times when the front wheels STILL get a bit light -
That's usually only when I end up with a full box, with some sod or roots that keep the box from dumping when I raise the blade - when I had only 400 lbs on the front, the wheelies would happen just going up a hill. In all fairness, I DO have a QH on the tractor, which shifts implements back about 4-1/2" and DOES make a difference - still, that box blade wouldn't have to work TOO hard to stop your tractor -
Things that would help -
If your tractor has a FEL, pick up a fairly full bucket of material and keep the FEL curled and BELOW your line of sight; that'll balance things better, + give your front wheels better traction.
Don't use a QH with the blade, a full box that doesn't wanna dump can exceed your lift capabilities even WITHOUT the extra 4-5" on the hitch.
If you haven't already, add TnT (Hyd toplink and side link) - those will REALLY bring out all the possibilities of that implement.
There are multiple versions of those blades - mine is the one with hinged rear blade - it has the option of being locked DOWN - if yours is that version (AND you have TnT) you may find you leave it locked DOWN - this lets you tilt the blade to the rear, which raises up the FRONT blade and floats the implement on the REAR blade (DIG less, SMOOTH more)
There's an excellent "beginner's guide" to running a box blade on here;
https://www.tractorbynet.com/forums...e-using-box-blade.html?highlight=beginner+box
Don't worry about hurting that blade, just your tractor - the PLUS side is, you can trade up your tractor a LONG ways and not hafta get a new box blade :D
HTH... Steve
   / Gannon/Woods HD4272 hydraulic box blade #5
Thanks
More than likely it will be a bit much for your CK4010HST. So unless he gives you a "really" good price, not sure that it would be the best alternative for your application.
Good luck. :thumbsup:
   / Gannon/Woods HD4272 hydraulic box blade #6
$800
Other than some surface rust it's in great shape. The scarifiers and blades look almost unused. It does have the hinged rear blade.
I'll need to bush it to Cat 1 size for the pins unless there's a better way to do that?
   / Gannon/Woods HD4272 hydraulic box blade #8
Mine cost close to 3k best I remember.
I was looking at a Land Pride BB2572 which is not hydraulic. They wanted $1500+ tax here for that. $950+ tax for the BB1272 which is a lightweight unit. Seems like this is worth a shot.
   / Gannon/Woods HD4272 hydraulic box blade #10
$800
For that price I would buy it and I have ZERO reason to have it other than to resell it and make some extra $$$$.
Try it, if it works for you, then GREAT. If it's simply to much implement for what you have, you can always sell it and get enough to get a 65" unit that fits your needs better. ;)
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
Flatbed Truck (A55973)
gps trailers (A56859)
