Replacing axles - brakes on both or one?
   / Replacing axles - brakes on both or one? #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I'm replacing the axles on a lowboy utility trailer. Going from surge brakes which never worked to electric brakes. Biggest load is a skid steer, pulled by my F250. What are opinions on brakes on both axles vs just on axle?
   / Replacing axles - brakes on both or one? #2
Number of brake axles can effect you licensed trailer weight in some states. In mine 3001-5000 lbs requires brakes on one axle. 5001+ requires brakes on all axles.
Trailer is registered as a Farm Trailer in Texas. There are very minimal requirements.
   / Replacing axles - brakes on both or one? #4
Requirements or not, it's very comforting to have the load behind you stop readily when you need it to. My son added brakes on the second axle of his Hudson 10k# trailer and it made it much nicer to tow. I vote for brakes on both axles. You'll like the upgrade to electric brakes in any case.
   / Replacing axles - brakes on both or one? #5
A skid steer is usually heavy enough to warrant brakes on both axles.
I agree.
   / Replacing axles - brakes on both or one? #6
^^^^^Yup!
   / Replacing axles - brakes on both or one? #8
^^^^^Yup!
Another vote. If possible, do both axles. Who knows whose life you may save.
   / Replacing axles - brakes on both or one? #9
I don't think anyone towing ever said "man my rig can stop too quick". Ever.
Go for brakes on both axles!
   / Replacing axles - brakes on both or one? #10
I'll 2nd that.
The 3 things you care about when towing (or just driving actually) in order of importance:
Stopping
Suspension & chassis
Power
Wimping out on the most important is just wrong.
I've stopped too quick on occasion but wasn't because of trailer brakes
   / Replacing axles - brakes on both or one? #12
If electric brakes is what you are going to then do brakes on all axles
   / Replacing axles - brakes on both or one? #13
I have smaller utility trailer 5'x 8' wood floor, can haul 1600 pounds. Bought it for supply runs for weekend home remodelling. Been a fantastic addition, good size and capacity instead of hauling larger trailer with pickup. Which leads me into my question, is it possible to add electric brakes to a smaller axle? I pull with a Subaru Forester, on third set of brakes. Brakes on the trailer would help with control and cost of brakes on the car every year.
My old 1992 Doolittle 16' trailer only had one axle braked, added brakes to the other extremely easy and worth every penny, much safer to use after that. My brother in law borrowed last year and both axles folded up like a cheap camera. This year was the year to install two new Dexter 3500 lb axles and bring it back to life.
   / Replacing axles - brakes on both or one? #14
Look at the end of the axle just inboard from the wheel bearing, if it has a square plate with 4 holes to mount the brake backing plate you're good for adding brakes. Just matter of getting correct diameter for wheel size.
   / Replacing axles - brakes on both or one? #15
Can't have enough Brakes!
   / Replacing axles - brakes on both or one? #16
My experience is that surge brake failures are often caused by crappy master cylinders. If someone made a master cylinder that didn't rust, it would be great.
I believe these might be a good possibility for surge/disk brakes. But I have no experience with them.
Tie Down 1" Trailer Disc Brake Kit | Overton's
In your case, electric will be a good way to go.
   / Replacing axles - brakes on both or one? #17
Yes I agree brakes should be on both axles with that weight.
thanks for the replies, now I just have to find the time to do the work
   / Replacing axles - brakes on both or one? #20
Well how are the brakes working since their on both axles ?
Great! Will put you through windshield. Didnt realize just how depleted the old brakes were, and using trailer in that condition was dangerous and unsafe. Run controller around 2 to 3 on Doolittle trailer, and 4 to 4 1/2 on my dump trailer with 3 1/2 tons of stone dust.
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A56438)
2024 Kubota...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
